monitor 10 - problem with hi freq
shaike_adler
Hi
I have the monitor 10b speakers for about 14 yesrs without any problems.
Now I have problems it's looks like the twitters are not working (the twitter its self looks good) (I have the problem with both of the speakers.
Can you please advice. Do you have the drawing of the cross over (I have electronics education so may be I'll find the problem my self)
Shaike Adler
Shaike Adler
Post edited by shaike_adler on
check and replace the fuse on the back of the speaker.. probably blown.
it's the most common reason a tweeter suddenly stops working.
welcome to club Polk!PolkFest 2012, who's going>?
Welcome to Club Polk. Here is the thread you are looking for....
If the problem is in your tweeters and not in the crossover, you may want to consider the silk dome replacements. They are supposed to be quite the upgrade over the stock SL2000's.
If you don't have a fuse on the back, it's possible part of the crossover(poly switches) or the tweeters themselves are blown. If it's the latter, I'd also recommend the silk dome replacements. They're available from Polk and if you tell them you're a member here, you get free two day shipping."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
I don't have a fuse on the back, I have something white on the cross over but I don't think it's a poly switch.
Can you tell me how the poly switch look like?
I have the sl2500 and one of them have high resistance (like open) do you have any advices?
The silk dome are replacement for the sl2500 too, do I need to change both tweeter to the silk or only the one with the problem?
Thanks shaike -
If you replace a tweeter, replace both.
The resistance of the tweeter(out of circuit) should be like 3.5 or 7.0 ohms. After that checks out, consider the crossover network(capacitors and inductors). -
Hi all
Can someone tell me how the Polly switch on the crossover look like?
I have a problem that the tweeter some time is working and some time not working.
I have some white component on the PCB of the crossover (on the second side of the resistors and the capacitors of the crossover)
Thanks shaike -
It will typically be either a tan or blue disc shaped piece less than 1/2" in diameter and around 1/16" thick or so.
If it sometimes works and sometimes doesn't, that sounds like a poly switch issue but sometimes can ne other things. One easy way to figure out if it's the poly switch is to take a short lead of wire and connect it across the 2 leads coming from the disc...effectively, taking it out of the loop. Try that. Also, is it cutting out at higher volumes or at any range?Richard? Who's your favorite Little Rascal? Alfalfa? Or is it........................Spanky?.................................Sinner. -
The tweeter are disconnected at regular volume levels.
According to your description it's look like I don't have a Polly switch in my crossover.
Thanks shaike -
Poly switches look like a tiny capacitor and is usually blue, yellow, or brown. There are diagrams here: http://www.polkaudio.com/forums/showthread.php?t=38755
This one is probably yours: http://www.polkaudio.com/forums/attachment.php?attachmentid=18776&d=1155784729"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
