Totem Storm & Martin Logan Depthi subs...
pearsall001
pearsall001 Posts: 5,299
edited January 2008 in 2 Channel Audio
Yeah, I'm still kicking around the idea of adding a sub strictly for two channel. HT is well covered with my SVS cylinder. Any thoughts on these two guys? They both come well reviewed. There's a hugh difference in price though, the Storm in approx. 1k less than the ML. From what I can gather they are both extremely musical & fast.
Post edited by pearsall001 on
  • hearingimpared
    hearingimpared Posts: 21,136
    edited January 2008
    You need a 12 step program.
  • pearsall001
    edited January 2008
    Look who's talking!!!! Aren't you draging my **** out tomorrow for "another" trip to Quest for Sound. I don't think you've walked out of there without spending at least $200. And you think I need help!! Ha!! :D
  • Shizelbs
    Shizelbs Posts: 7,433
    edited January 2008
    There is a nice looking depth on the 'gon right now. Snag the hell out of it. I want to hear your thoughts.
  • mantis
    mantis Posts: 17,477
    edited January 2008
    The Depth is a proven well musical sub. I love it to death. I believe Martin Logan from day one has entered and mastered the sub market. I was shocked the first day and to this day Impressed with there subs. Not just the Depth but the entire line.
    Simply amazing.
    Dan
    Dan
  • dave shepard
    dave shepard Posts: 1,334
    edited January 2008
    You will have no regrets at all. ML makes some very nice subs and they perform very well in HT too. They look small (and they are) but perform as though they are 3X's there size. Fast and accurate.
    Dave
  • pearsall001
    edited January 2008
    Zero wrote: »
    Oh hell, I'll respond here as well. It's a matter of determining what you want.
    The little Storm will be slightly quicker, and will have a big leg up in regards to tone.
    The Logan's are no slouch for speed - having a big leg up on clean, dynamic output.
    You could have at least changed the wording a little! :D From what I can gather they both are excellent performers. The ML is about twice as expensive as the storm, I'm wondering if it will perform 2x better? These are the tough decisions one must make. I think it's time for my prozac now.
  • AndyGwis
    AndyGwis Posts: 3,655
    edited January 2008
    I'd go with one totem to start. If it leaves you wanting more, get a second one.
    Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
    Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850
  • pearsall001
    edited January 2008
    Zero wrote: »
    I second Andy's suggestion. Even if you decided to go a different direction (ACI, for example)... I'd go with the less expensive sub and get two of em'. They will be FAR easier to integrate and will give you true left/right separation. The difference's are huge. Once you go dual sub's - there ain't no goin' back *unless its no subs*.
    Depending on which preamp I decide to keep...the Krell or CJ. If it's the Krell (I'm leaning that way :)) The ACI subs won't work. The way they do the hook up they use the RCA on the power amp. I'm running in balanced mode. I already emailed ACI & they said that at this time they have nothing in the works for balanced connection hookups. They do it completely differently than other sub manuf.
    I do like the idea of dual subs. Why is that easier to set up vs a single sub. I would think it's a tougher integration. I'm a novice when it comes to sub set ups.
