5 channel amps
MrNightly
So I'm beginning my search here... I am thinking about something along these lines:
The Sunfire TGA 5200. It will be used 90% HT. Would a B&K Amp be better or possible an Adcom for cheaper but still have enough power to push my speakers. I will probably step up to either the RTi10's or 12's so that when I listen to music I can use a Pure Direct mode with the mains.
I know I need something... the power is calling!
Any thoughts would be greatly appreciated. I will definitely being buying used, so take that into play as well.
Honoured to be, an original SOPA founding member
Stuff...
RTi12's - front
CSi5 - center
FXi3's - surrounds
RTi4's - surrounds
SVS PB12-NSD/2 - sub
Denon 3805
Rotel RB-985 5-Channel Amplifier
Stuff...
RTi12's - front
CSi5 - center
FXi3's - surrounds
RTi4's - surrounds
Denon 3805
I use a Parasound HCA-2205a...
220 @ 8ohm
300 @ 4ohm
Running the Full LSi 5.1 (9,7,LsiC) with it...
Sounds great !Cary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Cary Audio V12 amp (Jag Red)
Jolida JD-100 CDP
SVS PC-Ultra Sub
MIT Shotgun S1 I/C`s
AQ Black Thunder Sub Cables
PS Audio Plus Power Cords
:cool: -
Although I was thinking of getting a big damn tube amp to push my SRS's I'm now convinced that Cary's all-world Cinema 5 (or maybe A-5 if I "cheap" out) is gonna be the ticket for bi-amping the SDA big boys.
In other words, do it to it, dude.
WesLink: http://polkarmy.com/forums
Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d -
Which pre/pro are you guys using.
My AVR is a lemon and I'm checking out the field. -
Wes
Yeah Man !
That Cary Rocks !hearingimpared wrote: »Which pre/pro are you guys using.
Denon 3802 for the pre/pro, but I want to get the Parasound 7100 or the 2500u....but no need right now as the Denon does well enoughCary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Jolida JD-100 CDP
SVS PC-Ultra Sub
:cool: -
220 @ 8ohm
300 @ 4ohm
Sounds great !
Same here...less the LSi's...for now anyway.
THE SYSTEM
Polk Audio LSiM 707 Mains
Polk LSiM 702 f/x Surrounds
Polk Audio LSiM 706 C Center
SVS SB-17 Ultra Subwoofer
Rotel RSP-1582 Pre/Pro
Rotel RMB 1585 Amplifier
Oppo UDP-205 Blu-ray Player
Samsung PN64D550 64" Plasma -
I also have the rti8's, csi5, and rit4's and will need to add external amplification at some point. Will something around 125 to 150W be enough, or will 200W be too much. I guess I'm really limited by the rt4's, but they could be attenuated.
Jeff1, A few back I drove CSi5, RTi100's and Rti6's with 120wpc and it was plenty.Michael
NORTH of 60° -
Earthquake Cinenova for HT.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000 A
Parasound HCA 1000
Oppo BDP 95
Von Schweikert LCR 4 Center
Totem Mask Surrounds X4
Sony PS3
Squeezebox Touch
Cary Cinema 6.
Venom -
I would look at upgradeing the front speaks first and then grab an amp.
Sunfire is good ,B&K,is warmer,Adcom,Parrasound,all will do what you want.
You mat/maynot notice that big of an improvement with the 8's.Try an borrow a amp from a bud nearby and see if you like it.Only you can decide if the coin spent is worth it.HT SYSTEM-
lsi 9's -
I have RTi8's, Csi5, and some BIC Acoustech surrounds which will be upgraded to FXi5's next week and I have an Emotiva LPA-1 using my Onkyo 705 as a pre. I mostly use it for HT, but have started listening to 2 channel music because the 8's sound so good coupled with the BIC H100 sub. The LPA-1 is a good economic choice and it does an excellent job IMO.
wingnut4772 wrote: »Earthquake Cinenova for HT.
Might be out of my budget
Unless... you are selling one?!?!
Stuff...
RTi12's - front
CSi5 - center
FXi3's - surrounds
RTi4's - surrounds
Denon 3805
Rotel RB-985 5-Channel Amplifier -
Nightly, you can get the Sunfire, or a 5 channel Outlaw, Rotel, B & K, etc. all of them will do a great job.
If you get 200wpc you will notice a difference with the 8's as well as the 10's or 12's when you get them.
Keep us posted on what you get!Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
Hi Jeff. There is no such thing as too much power when it comes to powering speakers. Your RT 4's will shine just like all of your other speakers with 200wpc.
I'm running a 405wpc amp to all of my speakers & it sounds great!:)I also have the rti8's, csi5, and rit4's and will need to add external amplification at some point. Will something around 125 to 150W be enough, or will 200W be too much. I guess I'm really limited by the rt4's, but they could be attenuated.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
So is there really that much a difference for a HT Application between say this Adcom and this Rotel???
Need to get my learn on with amps I guess...Honoured to be, an original SOPA founding member
Stuff...
RTi12's - front
CSi5 - center
FXi3's - surrounds
RTi4's - surrounds
Denon 3805
Sadly, I already sold it.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000
Oppo BDP 95
Sony PS3
Squeezebox Touch
What is your budget? I tried a Sunfire Cinema Grand vs. my Cinenova and much preferred the Cinenova. They usually go for around $1800-$2000 used...but you never know when another member might be selling on in the FM. -
Probably under $1000.
If I could find one super cheap in the $400 range that worked and did the job for HT, I wouldn't complain either
Stuff...
RTi12's - front
CSi5 - center
FXi3's - surrounds
RTi4's - surrounds
Denon 3805
I would go with B&K if I had that budget, but Parasound has some really good options at a lesser pricepoint, as does Outlaw.
This is cheap and would get the job done: http://buy.audiogon.com/cgia/cls.pl?ampsmult&1203881537Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850 -
I would say go Parasound as a second HT choice then. I prefer my Parasound over the Cinenova for music for the 2 channel.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000
Oppo BDP 95
Sony PS3
Squeezebox Touch
Since I can't buy right now anyways, this is some good info to consider! Thanks guys. I didn't even consider Parasound. Anybody know how they sound paired with the RTi line?Honoured to be, an original SOPA founding member
Stuff...
RTi12's - front
CSi5 - center
FXi3's - surrounds
RTi4's - surrounds
Denon 3805
Since you are not in the market yet, and i'm not exactly ready to sell yet as well..
This is my first amp, i purchased it used and i have been running my set of full LSI setup on it.
Outlaw Audio 750..
Does 165watts@8ohms x5
And 250watts@4ohsmx5
http://pdf.outlawaudio.com/outlaw/docs/750specs.pdf
And in the future I would be willing to sell it for 500 + s/h
This would definitely be on the cheap end(and it fits within your budget) and it does the job.,
I am saving up to get a Earthquake Cinenova Grande...Click here To see My system
Polk LSI15,LSiC, LsiFX, SVS PB-12 Plus/2, Blue Jean Cables,Onkyo Pro PR-SC885P, Earthquake Cin -
I think they are a perfect fit, myself..
I have always love the HCA line with the RTi line..
I have had the RT2000i`s , 55i`s, 38is,15i, and a few different CSi centers in the mix..
The kinda bright tweets with the semi laidback Parasound amps works perfectly
you can find great deals on 8/10 - 9/10 gear for about 1k to $1400
I scored my amp in mint condition , with less than 50 hrs on it for 1250 !!!
I think Parasound is your best bet...and yes 200w minimum to make them sund thier best....not to make them loud, but to give them headroom to breathe...
ymmv of courseCary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Jolida JD-100 CDP
SVS PC-Ultra Sub
:cool: -
Outlaw Audio 750..
I will keep this in mind...
I think after the brief comments here, that a Parasound amp would actually be exactly what I'm looking for, but I don't know if I want to drop over 1K yet... I'll hook up with you via PM mwaarna, when the time gets closer!
Beard - thanks for the clear description on the Parasounds and the RTi's! That was extremely helpful! Now I just need somebody to sell me their RTi10's or 12's!!!
Stuff...
RTi12's - front
CSi5 - center
FXi3's - surrounds
RTi4's - surrounds
Denon 3805
fry`s has a couple left..
I`m thinking of grabbing some 12`s just because
sometimes you can find outstand deals on parasounds...I will keep an eye out...
If you decide not to go with the outlawCary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Jolida JD-100 CDP
SVS PC-Ultra Sub
:cool: -
Does anybody have any recommendations on this fella: Acurus 125X5
It's been offered at a reasonable price point... I really am looking for something that will not have to be upgraded for many moons! I'm kinda torn between saving a little more for a nice parasound (1K plus) or going something in the $300-400ish range.
Most likely, I will be staying with the RTi line for speakers for a while. I just like the way they sound and look. Probably move to a 7.1 when the basement is finished, but the Denon will be able to handle the rear's no problem.
Choices choices... so many and so little time
Stuff...
RTi12's - front
CSi5 - center
FXi3's - surrounds
RTi4's - surrounds
Denon 3805
You, sir, have a PM
Stuff...
RTi12's - front
CSi5 - center
FXi3's - surrounds
RTi4's - surrounds
Denon 3805
While I haven't heard one, I've yet to read anything bad about the Acurus amps around here.
I will never be replacing or thinking of upgrading the HCA-2205a
she`s a keeper ....and still breaking in !!
5.1 is great and if I do decide to upgrade it will be to go HiDef or Blu-Ray....but the amp ?..she stays !!!
I have not heard of the brand / model you speak of...
maybe someone else has...
goo luck with your quest !
Take your time and enjoy !!
(Pm`d ya back ) !!
p...I still have the 5ch amp that I replaced..if your good at fixing things....
I`m going to post it cheap on CL to see if someone wants to mess with itCary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Jolida JD-100 CDP
SVS PC-Ultra Sub
:cool: -
http://buy.audiogon.com/cgia/cls.pl?ampsmult&1205447379 (no affil)
I just saw this...
there ya go !!Cary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Jolida JD-100 CDP
SVS PC-Ultra Sub
:cool:
