rti10 and HK-3485
wizzy
wizzy Posts: 867
edited January 2008 in Speakers
Hey Gals and Guys,
Do you think a HK-3485 (Harmon K - Link to product)
Would be sufficient to drive rti10's to a normal to above normal volume? I'm not looking for glass shattering loudness.
Comments on how they might match up?
Just so you know - I own the HK-3485 presently. Also have a old HK AVR 80 mkII, an really old Marantz (about 35wpc - think soothing blue glow) and a Pioneer VSX-816.
Specs from HK:
120 Watts per channel, 20Hz – 20kHz @ <0.07% THD, both channels driven into 8 ohms
150 Watts per channel, 20Hz – 20kHz @ <0.2% THD, both channels driven into 4 ohms
Post edited by wizzy on
  • wizzy
    wizzy Posts: 867
    edited January 2008
    Just noticed I've been a member for three years and that was post #1
  • AndyGwis
    AndyGwis Posts: 3,655
    edited January 2008
    I have an 3480 that has driven towers and bookies very well. I think it would give the RTi10s a good run, and you could always add an external amp down the road.
    I think you'd be surprised how well the HK will sound on the 10s.
    Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
    Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850
  • ben62670
    ben62670 Posts: 15,969
    edited January 2008
    Now you are at post two:) I would say welcome to CP, but it is a little late. Of receivers I think that yours is probably one of the better ones to drive RTI's with. I am definitely an amp guy. Even a lower powered high currant amp usually does better than a receiver. I would say go ahead, and try it. Also check out some HiFi shops that let you audition an amp in home. It's not so much about power, and high levels, but SQ. Let your ears be the judge. Receivers typically don't have the headroom, or dampening factor that bring out the best in real nice speakers. I strongly recommend using the search feature. There have been a lot of post recently on driving RTI's with amps. Also great deals can be found on used equipment like Adcom's, and Parasound's.
    Happy hunting, and if you want advice on an amp you are looking at please ask.
    Ben
    Ben
  • Wesley Snipes
    Wesley Snipes Posts: 26
    edited January 2008
    Wizzy,
    I am in the same boat. Let me know how those RTi's sound using your H/K.
  • wizzy
    wizzy Posts: 867
    edited January 2008
    Wizzy,
    You own the HK and are thinking of buying 10's?
    Wonder how much longer the Fry's deal will last ... it's been hitting all the deals sites in the last day or so
  • Wesley Snipes
    edited January 2008
    Sorry, I have bought the RTi 10's (I haven't set them up yet) and I am looking for a new AVR to use with them.
  • wizzy
    wizzy Posts: 867
    edited January 2008
    Thanks everyone who answered!
  • jakelm
    jakelm Posts: 4,081
    edited January 2008
    wizzy wrote: »
    Guess we wont see you for another 3 years.;). Good luck getting to 1,000...:p:p
    Monitor 7b's front
    Monitor 4's surround
    M10's back surround
    Harman/Kardon AVR-635
    Oppo 981hd
    Denon upconvert DVD player
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
    Dont BAN me Bro!!!!:eek:
  • Kex
    Kex Posts: 5,205
    edited January 2008
    FWIW, the modest h/k 147, which claims just 50w/ch in stereo use, was measured in a December 2007 bench test to actually output about 90w/ch in stereo. I wonder how much that 3485 actually does put out.
    http://hometheatermag.com/receivers/1107rack/index5.html (first paragraph below the graph).
    Otherwise, in two channel, I have tried NAD, and even rated at just 50w/ch it totally blew the doors off. I wonder if anyone here is using one of those in a two channel setup using RTi10s.
    Alea jacta est!
  • AndyGwis
    edited January 2008
    Wow, I just looked up the HK 630 (the version before my 635) on hometheatermag. It does 147 watts into 4-ohms in stereo. That's pretty impressive for a receiver. . . I guess their claim of 45 amps of current might be true.
  • jakelm
    jakelm Posts: 4,081
    edited January 2008
    AndyGwis wrote: »
    And I think I read somewhere, Andy , that our 635 has a bigger power supply than the 630. I forgot where I read it.
    I dont know about you, but I'm perfectly happy with mine, even though I have no HDMI
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
