SR124 DVC Enclosure
Kinetic
Hello Polk Audio Team
I recently download a software to design my enclosure, this is for one Polk Audio SR 124 DVC Subwoofer
all the walls are made of 3/4 MDF, and the front one is 3/4 + 1/2 MDF
height: 370 mm
Long: 780mm
deep: 246mm
for a total of (46.440 Liters) - (the little reinforcement)
the Recomended eclosure is 46.439 Liters
Any recomendation?
is my design ok?
height: 370 mm
Long: 780mm
deep: 246mm
Any recomendation?
is my design ok?
Z
/////Alpine CDA-9887 HU
/////Alpine KTX-1000EQ
/////Alpine PDX-4.150
/////Alpine PDX-1.1000
Polk Audio SR 6500
KnuKonceptz MKS Kable
G35
/////Alpine SPX 17PRO
/////Alpine SWX 1243D
Polk Audio SR 6500
G35
Post edited by Kinetic on
I'm sure you'll want someone at Polk to chime in, and I'm sure they will (if for some reason they dont, call there Customer Service, they'll take care of you right quick.
The displacement seems right in theory, I'm sure these drivers were designed to work in relativly small enclosures, since they are actually meant to be small enough to be able to fit in a wall or floorboard (the enclosure, as well as the driver)
saw these at the last polkfest, and the displacement you list sounds about was in Ted's wall.
Like I said, calling Customer Service if they dont chime in here will be a good quick way to double check
*************oooops***************
never mind, I thought this was the home driver, not the car driver. either way Car drivers are meant to work in small enclosures as well, so it looks like it should be fine, but call cust service anyway to be sureLiving Room 2 Channel -
Schiit SYS Passive Pre. Jolida CD player. Songbird streamer. California Audio Labs Sigma II DAC, DIY 300as1/a1 Ice modules Class D amp. LSi15 with MM842 woofer upgrade, Nordost Blue Heaven and Unity interconnects.
Upstairs 2 Channel Rig -
Prometheus Ref. TVC passive pre, SAE A-205 Amp, Wiim pro streamer and Topping E50 DAC, California Audio Labs DX1 CD player, Von Schweikert VR3.5 speakers.
Studio Rig - Scarlett 18i20(Gen3) DAW, Mac Mini, Aiyma A07 Max (BridgedX2), Totem Mites -
I'm sure that would be fine for a car audio box. I think going 1 1/4 thick on the front is a bit excessive for that that subwoofer, but if you want to go the extra mile for it then go for it.
If it was me, I'd save the aggrivation and just do the 3/4 front, you won't notice the difference with a single sub.
