sub woofer blown? throw some advice at me
Jen.Bonas
Jen.Bonas Posts: 1
edited December 2007 in Troubleshooting
Im running a 15" sub of my 4ch amp. everything worked fine for about a month and a half.
now just yesterday started to cut out. now no bass is produced from the sub at all, unless i apply a light even pressure to the ring surrounding the cone.
Ive checked and re-wired the amp and all the sub wires they all appear fine. strangely when applying the light force to the cone, the bass produced is perfect exactly the same as when the sub was runnning fine. without the pressure though, no sound is emitted!!!!
any1 got any ideas?
Cheers for any advice in advance :)
Post edited by Jen.Bonas on
    treitz3 Posts: 19,279
    Get a new woofer. You have compromised the coils.
  • peffy03
    peffy03 Posts: 50
    burnt voice coil definately
    -Jeff
    My System:
    Onkyo Sr604
    Carver 125x2
    Polk Rti 10 (biamped)
    Polk Monitor 30
    Polk psw10bk
    Polk Rti6
    polk CSi3
    Monster ripoff wire
  • BaggedLancer
    BaggedLancer Posts: 6,371
    Definately a compromised voice coil without a doubt. It probably detached and by pushing it in you are making the connection again.
    You said you are running the sub off a 4 channel amp? Are you running it off a single channel or bridged? Are you sure you have the the correct ohm load and enough wattage to power the sub? There are VERY few 4 channel amps I know that could power a 15" sub off 4 channels bridged let alone a single channel.
    Take a look at the rest of your system and make sure it's hooked up before you just pop another 15" subwoofer in, you wouldn't want it to happen again.
