Infinity cascade twelve,hsu,outlaw or dsw pro sub?
polkseller
polkseller Posts: 184
edited December 2007 in Speakers
I can have a nice deal on the Infinity cascade twelve and the Polk dsw pro 10 incher.
But i'm also interested to HSU VTF-1 and the outlaw LFM-1compact.
I can have them for under 500$ each.
wich sub has the best frequency response, design and feature ? Do you haev one at home ?
Post edited by polkseller on
  • polkseller
  • SKsolutions
    SKsolutions Posts: 1,820
    no-eye deer
    -Ignorance is strength -
  • mantis
    mantis Posts: 17,412
    Most subs in that price range are not that good. Martin Logan makes great subs under 1000.00 . You might want to shop around before you spend your money.
    Think Martin.....
    Dan
    Dan
  • Early B.
    Early B. Posts: 7,900
    For $500 you can buy a better sub than the ones you have listed. For instance, consider the Hsu VTF-2 instead of the VTF-1.
    "God grooves with tubes."
  • fatchowmein
    fatchowmein Posts: 2,637
    I have the LFM-1 Plus and love it. Works great for small to medium size rooms, not sure about large rooms since I don't have one, but then I'm not a sub expert.
    May help if you describe what you want to do and where you're planning to put it. A 350W downfiring sub in a 10x10 bedroom may be overkill. :)
