Just bought an HK AVR-745 to replace a denon 3802 did I screw up?
Dannieboiz
Dannieboiz Posts: 242
edited December 2007 in Electronics
I jumped on an HK AVR-745 today since the price was at the right point. Little did I know it's only rated at 85wpc while my denon is 110wpc... I'm powering RTi10 and CSi5 in the fronts. I don't ever planning on to getting an external amp. I hope I did the right thing.
Sammy UN55C6400
Onkyo TX-SR875
Def Tech: Mythos One, Three, Six
Velodyne DPS-12
MartinLogan Dynamo 10
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    edited November 2007
    I don't think it's really be better or worse, just different. It may be more up to date, I'm not sure, but new bells and whistles is all you'd be gaining.
    Don't worry about the power ratings, HK stuf is rated conservatively, that 85 will be every bit as much as those 110 on the Denon.
    I personally prefer the Denon, but that's subjective.
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    I doubt the Denon at 110w is more powerful then the HK, as HK is usually rated for what it will do and the others can be a bit over rated. So saying that I think it most likely a wash.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • millerman 3732
    millerman 3732 Posts: 1,488
    Make sure you give that HK room to breath, those things heat up quick, at least mine does and I don't even use the internal amp.
    Casey
    H/T: Epson 6500ub
    Sony UBP-X800
    Toshiba HD-XA2 (HD-DVD, CD)
    Onkyo 805 (pre-amp)
    Outlaw 7125
    Polk RTi 10 (bi-amped)
    Polk CSi5 (bi-amped)
    Polk RTi6
    SVS PB 12 plus/2
    Velodyne SMS-1
    TV Rig: Samsung 50'' 4k display
    Polk Signa-1 Surround bar
  • shack
    shack Posts: 11,154
    May be a lateral move at best. I prefer Denon over HK...not a big fan of HK build quality...but you may like it better and can sell the Denon. If you find it's not an improvement or you like the old Denon better...you can always sell the HK.
  • Dannieboiz
    the only real way to test this is to hook this baby up..... But what about HDMI 1.1 on the HK? Do I care or get a HDMI 1.3? I do have a 1080p tv and my HTPC is 1080p capable. :(
    I'll report back in a couple hours when I'm done setting things up
    Sammy UN55C6400
    Onkyo TX-SR875
    Velodyne DPS-12
  • Early B.
    Early B. Posts: 7,900
    The HK will smoke that Denon...
    "God grooves with tubes."
  • shack
    shack Posts: 11,154
    Or just smoke.....
  • rskarvan
    rskarvan Posts: 2,374
    I've got the Denon 3801 and its just fine at 105 wpc. I can't see that a switch to HK will get you anything more. You would have been much better served by adding an external amp to your Denon 3802 to power your mains.
  • Dannieboiz
    I'm disappointed to say that the HK is a keeper!:D
    To be honest, I don't hear that big of a difference. It's got HDMI and the EZEQ for calibration wins over the Denon.
    Sammy UN55C6400
    Onkyo TX-SR875
    Velodyne DPS-12
  • engtaz
    engtaz Posts: 7,677
    Unless the HK has more bells and whistles, I think it was a step back.
    engtaz
  • danger boy
    danger boy Posts: 15,722
    it all comes down to which sounds better... at least to me it would.
    PolkFest 2012, who's going>?
  • Ron Temple
    Ron Temple Posts: 3,212
    It's the sound you're used to...I went from HK to Denon for about a month...then back to HK. It was fine for HT, but really sounded flat for music. Considering the price of the 745, I'd think you'd notice a difference and preference right away.
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • AndyGwis
    AndyGwis Posts: 3,655
    HK is awesome. Keep the 745. It's 85 is like 130 from Yamaha, Denon, and Onkyo based on my highly biased opinion.
    I have two HKs and love them.
    Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
    Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850
  • Dannieboiz
    There are two reasons why I'm really considering getting rid of the HK.
    1st. No 1080P this is important for me since my HTPC is 1080p.
    2nd. I can't force 5 channel stereo on all siginal. Only on certain signal and it's making me sick!
    Sammy UN55C6400
    Onkyo TX-SR875
    Velodyne DPS-12
  • rskarvan
    1080p with Blue Ray is absolutely stunning.
  • AndyGwis
    well, if you are needing 1080p with the power and such of the HK, you're probably gonna have to pay quite a bit more. I think the new Elites might be 1080p output.
  • AndyGwis
    I guess I could see that for some Dolby material, it will only play one of the dolby processing formats. But, you should be able to listen to any music you like in 5-channel stereo by pressing a button or two.
  • Dannieboiz
    dolby digital is when 5 channel stereo doesn't. How do I disable auto detection?
    I do have a Harmony 880 besides the 745 comes with what appears to be a Harmany 550. :)
    If you can show me how to disable auto dectection and if I can somehow make 5 channel stereo work on all input signal I'll seriously consider keeping this puppy. I do like the look and even the sound.
    Also to answer your remote question. It's not the HDMI (audio) that I care for. It's simplifying my system so others in the family can use it with little to no training. I've been trying to show my fiance how the 880 works for the longest time and still having trouble.
    I have a few music DVD but most importantly use my HT as the music source for my Karaoke system that have it's old dedictated vocal speakers so 5 channel stereo is crucial in my setup.
    Sammy UN55C6400
    Onkyo TX-SR875
    Velodyne DPS-12
  • Dannieboiz
    if I turned off the auto-poll and disconnect the analog would it still allow me to have 5c stereo?
    BTW: I've email HK 2 days ago but still haven't got a response.
    Sammy UN55C6400
    Onkyo TX-SR875
    Velodyne DPS-12
  • JoshParsons84
    JoshParsons84 Posts: 565
    Hey Dannieboiz, what condition is your Denon in? I might be interested if it's still in good condition and the price is right? How much do you think you'd sell it for? I've been wanting to do away with my Onkyo 503 (either sell it,trade it,or use it for a bedroom system) and get a nice Denon but never had had the funds to upgrade yet and I might be able to if the price is in my range for the 3802.
  • Dannieboiz
    that's really annoying, the Denon will do 5 channel stereo regardless if it's analog or digital.
    I tried to turn off auto poll but it still doesn't work. I hope there's a walk around for this cause I really don't feel like running another set of cables.
    Sammy UN55C6400
    Onkyo TX-SR875
    Velodyne DPS-12
  • BIZILL
    BIZILL Posts: 5,432
    i feel your pain dannieboy. dannieboy, dannieboy, danniboy...(chumbawumba)
    but +2 as i cannot force my H/K7300 into 7.1 DD PLIIx mode!!!! it bugs me sooooo much i wanna get the onkyo 905.
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    7.1 SURROUNDS: RTI6'S
    XBOX 360
    WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
    http://polkarmy.com/forums/index.php
    bobman1235 wrote:
    I have no facts to back that up, but I never let facts get in the way of my arguments.
  • Dannieboiz
    ok so it looks like it's an HK thing, hopefully I can find a decent deal on an AVR 3808 :(
    Sammy UN55C6400
    Onkyo TX-SR875
    Velodyne DPS-12
  • Dannieboiz
    here's the response received from HK.
    Good morning and sorry for the delay. Unfortunately, since Dolby Digital
    is a default standard surround format, there is no way to bypass the
    format and switch to 5-channel stereo as long as you are using a digital
    input for that source. 5-channel stereo is a analogue surround format
    and you will need to either switch the output of the source to PCM from
    Bitstream or connect a 2nd set of analogue cables to the receiver to a
    different source input for analogue and then you can switch the surround
    mode to 5-channel stereo.
    Wonder why HK does this, Denon would let you do anything you want, its your ear, why force it. arghhh shame on them.
    Anyone have thoughts on the Denon 2808ci or 3806?
    Sammy UN55C6400
    Onkyo TX-SR875
    Velodyne DPS-12
  • disneyjoe7
    My old Onk 898 would do this so I always had an optical input alone with 2 channel RCA audio input. Just switching source if an issue came up where sound wasn't right.
    I lived so long with this problem I thought all AVR's did it, but I found out that my new PE 84tsi AVR had no problems with it so it's just feed optical from my problem source.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • ND13
    ND13 Posts: 7,601
    Congrats on the 745. I'd lay $$ on you being a happy camper, if I had any $$$ to bet.
    But, in reality, they're the two best in their price points, by far...IMHO. I've owned both in the past and I prefer the HK now, and like the others said, the HK will have a great high current amp section, with a signature on the warm side.
    "SOME PEOPLE CALL ME MAURICE,
    CAUSE I SPEAK OF THE POMPITIOUS OF LOVE"
  • Dannieboiz
    disneyjoe7 wrote: »
    How do you like your PE? The PE was a line that I was seriously considering.
    Sammy UN55C6400
    Onkyo TX-SR875
    Velodyne DPS-12
  • JoshParsons84
    I've got a question and I don't deem it necessary to start a thread over one question. What is a good AVR to put in place of my Onkyo 503 that has pre-outs but in the end will be used for a pre/pro?
  • Phier
    Phier Posts: 5
    Hello,
    I have hk avr 745 but it seems that hdmi output got broken, i am getting some blue stripes... Is it possible to keep avr for a sound and somehow to link it with some external device for hdmi out? Only?
    billbillw Posts: 8,373
    Phier wrote: »
    Hello,
    Yes, run your HDMI outputs (from source devices) directly to the TV. Use separate digital coax or optical from the source to the HK AVR. If your sources do not have optical or digital coax, you might get by with running the digital audio out from the TV back to the AVR. There are obviously some limitations to this, and it also assumes your TV has enough HDMI inputs to handle all your sources, but I had an even older non-HDMI receiver in my living room setup like this for years and only recently replaced it.
    If that doesn't work, well, its probably time to upgrade receivers. 15+ years has seen quite a bit of advancement to AVRs.
