I-sonic / power failure
LokiRN
LokiRN Posts: 1
edited November 2007 in Troubleshooting
I have had my i-sonic over a year and have the following problems -anyone else? I have not yet notified support but will do so tonite.
After a power outage the i-sonic resets to the screen that displays choice of time zones. Using the menu buttons can restore the clock display which has the correct time- BUT if the alarm clock was due it would not sound.
Also, occassionally--cause unknown-- the time display freezes and the i-sonic must be turned off and back on to then manually reset the time. Obviously no alarm clock sounds in this case either.
This is making it very unreliable due to the number of electrical storms (Florida) and power outages/surges from nearby construction or other causes.
I hope this can be easily fixed since I otherwise love the device (except for the akward menu system)
Anyone else with similar problems?
Thanks, Mike
Post edited by LokiRN on
  • steveinaz
    steveinaz Posts: 19,538
    Post this in "troubleshooting"
  • RuSsMaN
    RuSsMaN Posts: 17,986
    Moved.
    Mike, I'll have Ken check this thread and get you squared away.
  • archipotter
    archipotter Posts: 1
    I am having similar problems. My unit just started to make a humming sound. This evening when turning it on, it required a time reset. Then when installing a DVD, it appears to restart, the screen goes haywire, and it requires a time reset. It repeats this over and over, and will not play DVDs or CDs now. Any suggestions?
    Mike
  • [Deleted User]
    [Deleted User] Posts: 7,658
    Hello,
    If anyone is having difficulties with their I-Sonic, or any Polk Audio product, please telephone us at 1-800-377-7655 for the United States and 1-905-457-0164 for Canada and we'll be happy to help. You may also send us an email message at polkcs@polkaudio.com and we'll be glad to help. Keep in mind we will be closed this Thursday and Friday, but return on Monday the 26th.
    Regards, Ken
