Shortie Speaker Stands
BaggedLancer
Checked www.racksandstands.com
Checked www.ebay.com
Checked www.craigslist.com
I want something like the attached pictures. My intention is to cut them down to about 5-6 inch stands and use them on top of a bureau so they must be able to be taken apart. Wood or metal is fine, I have enough tools I can cut either. I found these on craigslist but they are just too far away from me to make the non negotiable trip worthwhile.
Thanks,
Mark
Thanks,
Mark
Post edited by BaggedLancer on
Awesome thanks.
- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
A cup is about 5-6"...
Just fill them with stand -- wrap bottom with plastic (rubber band around the bottom to seal)
Turn it upside down, put speaker on top -- use two cups per speaker if you want to go high end...
Awesome stuff- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Or you could use a few of these.
"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
thanks anyway kex
What i thought was going to be a fairly common thing of "table stands" it seems only Bose jumped on this bandwagon....
