Monitor 60 problem
Jets69
Jets69 Posts: 1
edited November 2007 in Troubleshooting
I have owned these for 2 yrs. now. I recently discovered that when I turn the volume up around half way on my yamaha htr-5990, the receiver shuts down after about 2 minutes and says check speaker wires. I have checked the wires and there are no problems with the wiring. The wiring is 14ga speaker wire. Any ideas would be greatly appreciated. Thanks
Post edited by Jets69 on
  • Jim Shearer
    Jim Shearer Posts: 369
    My guess would be that you have run out of power, started clipping & over heating. If you want more volume, then you probably need a separate amp w/ more watts. More speakers are destroyed by weak, over-driven amps than by big, high power amps.
    Cheers, Jim
    A day without music is like a day without food.
