Subwoofer problem....
shawn474
shawn474 Posts: 3,052
edited November 2007 in Troubleshooting
I've posted on here before about my subwoofer trouble. It makes a strange noise (almost like a record scatching) on powering up coming out of stanby. At no other point during music or playback is it heard. It is a JBL E250P subwoofer and is not under warranty. I tried a cheater plug and it did not work. I -emailed JBL and this was the response:
"Good morning and thanks for your inquiry. I am sorry to hear of the
trouble with your subwoofer. From what you are describing to me it
sounds like the amplifier is spiking every time it receives an incoming
signal therefore triggering the unit to come out of standby. This noise
could sound almost like a chirping sound....This can be repaired by any
authorized JBL service center and I have attached a link to our locator
to find the closest repair center in your zip code area."
It is not worth it to me to have it serviced because it works perfectly fine. But, it annoys me to the point where I would like to try to fix it myself if it is easy enough. Any suggestions on how to troubleshoot this problem and fix it? Thanks in advance for any responses.
Take Care,
Shawn
Shawn
AVR: Marantz SR-5011
Center Channel: Polk LsiM706c
Front: Polk LsiM703
Rear: LSI fx
Subwoofer: SVS 20-39pci
DVD Player: Sony PS4
Post edited by shawn474 on
  • dorokusai
    dorokusai Posts: 25,577
    I would suggest setting it on fire and buying this PSB I have for sale :D
    It may be feedback being amplified, just like they said. That is most likely a board level fix.
  • shawn474
    Mark,
    I would love to buy that sub! Problem is btween my duaghter's b-day 2 weeks ago, my wife's b-day yesterday and christmas coming up - No can do!!! If it is still available and I have the funds after doing some Christmas shopping, I will let you know. :)
    Shawn
    Shawn
    Front: Polk LsiM703
    Rear: LSI fx
  • dorokusai
    You know I'm friendly to people who live right down the street silly....email me, let's chat.
  • burdette
    burdette Posts: 1,194
    Is there an option of taking it off standby and just leaving it on?
    My sub amp has "on" and "auto-on"... I consider 'auto-on' sort of like standby. Problem is, the threshhold of the input is above the signal level, in other words, it doesn't 'auto-on'. So, I just leave it 'on' all the time.
    I don't know if that would help you, but you could see if you have an 'on' position, and try that.
  • shawn474
    burdette,
    I'll give that a whirl and see if it works.
    thanks,
    Shawn
    Shawn
    Front: Polk LsiM703
    Rear: LSI fx
  • Sherardp
    Sherardp Posts: 8,038
    SVS for sale in the FM, shoot Wingnut a PM. Now its time to get in the game with the SVS.
  • shawn474
    Problem solved twofold:
    1. I usually cable tie all the cords to keep them neat and tidy. After I took off the cable ties, the problem noise went away. I guess I should think twice about the cable tie idea, huh?
    2. I bought the PSB subwoofer from Mark and the thing rocks. (Thanks again, Mark).
    Shawn
    Shawn
    Front: Polk LsiM703
    Rear: LSI fx
