RT2000P Crossover issues
Whateverer
Whateverer Posts: 57
edited October 2007 in Troubleshooting
I recently bought a pair of used RT2000p's and one of the crossovers is shot, All burnt up. So In trying to figure out what to do I have found that my crossover doesn't quite match the one in the schematic from this thread,
http://www.polkaudio.com/forums/showthread.php?t=38755
Here's a picture of the one good crossover,
http://img360.imageshack.us/img360/4181/dsc02677dg4.jpg
I would like to have a pair of new crossovers built but now these differences have raised some questions.
If anyone has any insight on this I would appreciate it.
Post edited by Whateverer on
  • ka7niq
    ka7niq Posts: 577
    edited October 2007
    Whatever wrote: »
    There are no more stock crossovers from Polk, just european ones.
    I think I have one good stock crossover.
  • Whateverer
    edited October 2007
    I don't quite understand your response. Your saying you have a stock RT2000P crossover? Does it look like the picture of mine?
    Well my crossovers do say RTE2000P would that mean there the European crossover? Or can you tell from the picture I posted above if that is the European version?
  • Systems
    Systems Posts: 14,873
    edited October 2007
    Sorry I can't shed any light on the differences in your XO and schematic but I find one aspect in RT2000 XO schem that is unusual.They are using a large (400uf)cap in series with the woofer which would act as a hi pass filter therefore possibly reducing the bass extension.I have never seen this done before in a two way design and can only guess its purpose is the reduction of excursion at very low frequencies and protection from a DC voltage.Inertesting.
    Testing
    Testing
    Testing
  • ka7niq
    ka7niq Posts: 577
    edited October 2007
    Whateverer wrote: »
    RTE means European, but check with Ken in Polk cust service, be sure,
    I have a stocK crossover around here somewhere, but it ain't gonna do you no good I do not believe.
    I had a crossover go bad in my RT 2000P's, had to order two new european crossovers.
    There IS a difference in sound, the european crossover smoother, more laid back.
  • Whateverer
    edited October 2007
    ka7niq wrote: »
    Do you know if they still sell the euro crossovers? How much where they?
  • ka7niq
    ka7niq Posts: 577
    edited October 2007
    yes, 48 bucks shipped for Club Polk members, they only had 150 of them left
  • Whateverer
    edited October 2007
    ka7niq wrote: »
    Oh thats not bad at all. Hope they still have some left!
  • Whateverer
    edited October 2007
    If anyone has a picture of the european crossover or a schmatic I would appresheate it.
    Also ka7niq just to be clear is it 48 for a pair or just one?
  • ka7niq
    ka7niq Posts: 577
    edited October 2007
    Whateverer wrote: »
    JUST one, but ask for Ken, and maybe he will feel sorry for you since Polk does not have the ONE crossover you need, making you buy two.
    Polk cust service is the BEST, for real.
    They take care of their people.
    Ask for Ken in cust service :)
    The European crossover sounds different, it is smoother, more laid back.
    Be aware of that, ok ?
    Some like a brighter sound, like the original RT 2000 P crossover
  • Whateverer
    edited October 2007
    ka7niq wrote: »
    Well I haven't really listened to them so I wont really know the difference.. The reason I would like to find a euro schematic is to confirm if I already have euro xovers thus I would only need to buy one. I suppose they should be able to confirm when I call.
    Just thinking out loud here but Ive read the RT2000i's arnt so "bright" maybe the euro crossovers are the same as the RT2000i's? Speaking of the RT2000i's it would be possible to just replace mine with 2000i's no?
  • ka7niq
    ka7niq Posts: 577
    edited October 2007
    I don't know if the rt 2000p european crossover is the same as the rt2000i ?
  • danger boy
    danger boy Posts: 15,722
    edited October 2007
    not that it's impossible.. but why would a pair of American Polk speakers have Euro crossovers in them? and if they do.. what's the difference? You may need to rebuild them yourself if Polk doesn't carry the one you need.
    PolkFest 2012, who's going>?
  • Whateverer
    edited October 2007
    danger boy wrote: »
    Well I'm not the original owner. So I'm just trying to figure out whats up with them, And mine definitely don't match the schematic of whats supposed to be the crossover.
    I'm hopeing I can confirm that mine are the euro crossovers so then I can just buy another if they have any left or get the euro schematic.
    ka7niq: Witch crossovers do you like better?
  • ka7niq
    ka7niq Posts: 577
    edited October 2007
    danger boy wrote: »
    Polk re designed the RT 2000P crossovers for the European market.
    The Europeans like a less bright, smoother sound I am told.
    My RT 2000P's crossover went bad, Polk had no more of them.
    So, I had to use what they had.
    All they have left are the European versions of the crossovers.
  • ka7niq
    ka7niq Posts: 577
    edited October 2007
    Whateverer wrote: »
    I like the stock ones better.
    The European crossover is a little TOO laid back, but I am i a pretty big room.
