Rt3000p Fried Amp / Replacement?
shopdog328
shopdog328 Posts: 25
edited October 2007 in Troubleshooting
All,
Just found the forum, lots of great info. Have a problem. My left channel sub of a pair of rt3000p speakers quit working. Sent the amp in to Polk, was told it was fried. they don't stock replacement parts any longer. They want 350 for a new amp. Had the same problem under warrenty with the right speaker a couple of years ago.
Did a search on the forum, but couldn't find if this is a good deal, or a design defect with the speakers. I don't use them hard so I am a little miffed at a 350 bill to replace what i think is a design defect.
So, does anybody have a spare amp laying around they want to sell, or any advice?
I need a better deal than 350 to keep my better half happy.
Thanks,
Jake
Post edited by shopdog328 on
    tonyb Posts: 32,963
    edited October 2007
    Never had an issue with mine over the years so a design defect....I don't think so.but you may be able to find a replacement bottom half of the 3000p's on e-bay for fairly cheap.
