RTi Power Consumption
hockeyboy
hockeyboy Posts: 1,428
edited September 2007 in Speakers
Will I have any trouble driving a small 5 channel system with 90 watts per channel? The equipment will be a Marantz SR5001 with RTi6's, RTi4's, and CSi3. My experience with Marantz is that they typically have more power than advertised but I am most worried about the CSI3.
My Main Gear
Mitsu HC5000 (Proj.)
Marantz SR8001 (AVR)
Sunfire TGA7200 (AMP)
Marantz DV7001 (SACD)
Samsung BD-P1500 Blu-Ray
LSi 15's (Front)
LSiC (Center)
LSiFx (Surrounds)
DUAL SVS 20-39 CS Plus
(Passive Subs)
Marantz IS201 I-Pod Dock[/SIZE]
Panamax M5300EX
Carada Criterion 106" Brightwhite Screen
Sunfire TGA 5200 & (4) B&W 605's in the party room
Post edited by hockeyboy on
  • zingo
    zingo Posts: 11,258
    I don't think it would be a problem. Marantz makes quality equipment and so I doubt it would be too shabby in the power department. That system should sound pretty good.
  • mantis
    mantis Posts: 17,378
    rti speakers are easy to drive. it will be fine.
    Dan
    Dan
  • janmike
    janmike Posts: 6,146
    Agreed. At one time I drove RTi100's, RTi38's, RTi6's and a CSi5 with a Yamaha RX-V1500with ease.
    Michael ;)
    NORTH of 60°
  • Willow
    Willow Posts: 11,231
    I drove rti4,rti8 and csi3 on a yammie rxv 540 then a HK335 before buying my monos.
  • John K.
    John K. Posts: 822
    Hockey, this is something that doesn't depend only on what the amplifier and speakers are, but is affected significantly by other factors, notably how loud an average listening level you use and how wide the dynamic range of the material you play is. For example, all your speakers are on the high side of average in sensitivity(no good reason for special concern about the CSi3)and will use 1 watt or a bit less at a comfortably loud average listening level. Brief peaks will take much more, again depending on how wide the dynamic range of the material being played is, but it's highly probable, as the other replies indicated, that your 5001 can handle this with no problem, so you shouldn't assume that there'll be a problem. Keep in mind that even if you got something with double the rating(i.e., around 180-200 watts)this would only increase the maximum loudness level possible by about 3dB(e.g., from 105dB to 108dB)which would be barely noticeable at such an extremely loud level. Again however, it's unlikely that you'd actually use the extra power capacity and unused maximum capacity is simply that: unused.
    F1nut Posts: 51,763
    An amp rated at 90 wpc is going to run out of steam (clip) much quicker than one rated at 200 wpc at the same (105dB for example) listening level. So, that unused maximum capacity isn't unused, it's reserve.
    That said, at reasonable levels, you should be fine with your set up.
    Tip: whatever John K. posts, ignore it as he has no effing clue as to what the hell he's talking about.
  • Willow
    An amp rated at 90 wpc is going to run out of steam (clip) much quicker than one rated at 200 wpc at the same (105dB for example) listening level. So, that unused maximum capacity isn't unused, it's reserve..
    Kinda like the army, if they need em he reserves are there !
  • aaharvel
    aaharvel Posts: 4,489
    John K. wrote: »
    SWEET! I'm going to the pawn shop first thing tomorrow and trade in all my h/k shite for a portable CD player to power my rti's.
    H/K Signature 2.1+235
    Jungson MagicBoat II
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
    "People working at Polk Audio must sit around the office and just laugh their balls off reading many of these comments." -Lush
  • McLoki
    McLoki Posts: 5,231
    aaharvel wrote: »
    dibs.... I will save you the trip. Send me your H/K crap and I will send you a really nice portable CD player that will output at least one watt. (no mention of the distortion needed to do it, but that is just a crap statistic put out by manufactures to get you to pay to much anyway.)
    I will pay to ship mine and you pay to ship yours. (only fair since I will have to unload all that stuff to some gullable soul once I get it....) :D:D
    Michael
