speaker help
simonsays09890
i have the polk db521 and the db691's hooked up in my car to a pioneer deh-p6900ub head unit. they sound great apart from i have noticed on one song called hellyeah by hellyeah there is a crackling noise coming from just the left speakers, its just part of the song it happens. other then that they sound ok. are my speakers blown or is there something i can do to stop this.
Simon
Simon
Post edited by simonsays09890 on
Hello Simon,
Thanks for posting your question on the Forum. The best thing to do is to play that same disc on another car system or home system. If you hear the same bad sound then you know it's a problem with the disc.
Regards, Ken
