Humming Rotel RB-991 - HELP
VXR8
VXR8 Posts: 291
edited September 2007 in Troubleshooting
Hi guys,
Need your help. I have purchased a used Rotel RB-991 Amp that has a very loud hum (no it doesn't know the words :p ). I have both my AVR and the amp going through a Belkin Pure AV power board, to condition the power, so that shouldn't be an issue?
I have moved the Rotel far away from any sources of interference, but still the same annoying hum. I note on some other similar questions, there is mention of a ground loop issue. What is actually meant by this - is it an internal problem within the amp, or is it something external you do to fix the problem?
So far, my dream of 200 watts a channel hasn't quite been that. Not my day really, as I received also a brand new Oppo DV-980 today that I ordered directly from Oppo, but the tray won't open :( . If I was in the US, probably could go and swap it easily, but as I'm in the land down under, not so simple :( .
Anyway, any tips on my humming going will be appreciated! Thanks in advance.
Regards - Gaz from the land of Oz
Main System
Denon - AVC-4700H
Emotiva - XPA-9
Cambridge Audio - Azur 851C - CXUHD
Polk Audio - Legend L800 - Legend L400 - Legend L900 - LSiM fx - OWM3
SVS - PB1000 x 2
Foxtel - iQ4
Belkin - Pure AV PF40
Sony K77A9G
Front Room System
PS Audio - Sprout 100
Cambridge Audio - CXC S2 - CA752BD
Sony - UBX800 4K BluRay
Polk Audio - Legend L200
Post edited by VXR8 on
  • sucks2beme
    sucks2beme Posts: 5,683
    Here's a good link
    http://www.smr-home-theatre.org/Ground-Loops/
    Bottom line- it's a common problem.
    In telecommunications, we go out of our way to prevent the problem.
    It causes mayhem with equipment and invites lightning damage. In
    home audio, It's just a annoyance.
  • VXR8
    VXR8 Posts: 291
    sucks2beme wrote: »
    Here's a good link
    Thanks S2BM,
    Interesting read! I think it might be my cable TV possibly causing the hum. I haven't had the opportunity yet to eliminate the causes, but will do later today. I literally have had no issues prior to the amp with the cable TV, but I suppose the 200 watts highlights the effect.
    PS - Oppo were great and are sending me a replacement unit - excellent customer service :D
    Main System
    Denon - AVC-4700H
    Emotiva - XPA-9
    SVS - PB1000 x 2
    Foxtel - iQ4
    Sony K77A9G
    Front Room System
