Serious Problem-- HELP!!
edited September 2007 in Troubleshooting
After almost a month of waiting, I just received and connectted my lsi 15's and center. (still waiting for surrounds to arrive). Problem is I think something is wrong with my right speaker. The sound coming out of the left and center is clear and loud. But the right is very soft. so soft that if i turn down the left speaker, i can barely hear the right speaker. I already double checked my speaker connections. before i call jr, i wanted to check to see if i was doing something wrong. i had previously run audessey set up with my onkyo 805 on my old polks and have yet to rerun it. so i turned that off. Any ideas.. so so frustrated right now.... help a newbie.
lsi 15's, lsi c, lsi f/x
onkyo 805
sunfire tga 5200
toshiba - xa2
panasonic bd30
sony kdl40v2500
svs sb12+
Post edited by margate21 on
Welcome!
    I would suggest you triple check your connections, then swap the speaker position. If the problem follows the speaker, there you go. If not, you might want to double check the settings on your equipment.
    I'm sure the forum can help you, relax, we're here to help.
    Mark
    • Make sure the nuts on the back of the speaker (with the brass jumpers beneath them) are all good and tight.
    • Make sure not even one strand of the speaker wire from the red side (positive) is touching anything on the black side (negative) and vice versa (at the amp and speaker).
    • As already mentioned, swap the speaker cables at your Onkyo for left and right. Does the problem follow the wires or stay in the same channel?
    Let us know - and we will help where we can. BTW - welcome to club polk.. :)
    Michael
    ok now if feel like a hypochondriac! i had a trunk near the right speaker and moved it 2 inches away and really do think it worked (is that possible) that being said i still think the left speaker sounds slightly louder. could that be due to the fact the wall is closer to the left speaker. i had read these speakers were finicky, wow.
    onkyo 805
    sunfire tga 5200
    toshiba - xa2
    panasonic bd30
    sony kdl40v2500
    svs sb12+
    Make sure that your speaker wire termination points (binding posts) are not tightened down on the speaker wire's insulation. I've done that myself and had similar results to what you describe. Then when moving the wires around the insulation pulled out and I had better wire to terminal contact which restored the audio level. Of course the terminal was now loose....
    The Beloved System:
    Parasound Halo P3 Preamp
    Parasound Halo T3 AM/FM Tuner
    Grant Audio Tube Buffer
    ADC Sound Shaper II IC Graphic Equalizer
    Polk XRT12 XM Satellite Radio Receiver
    2 Carver TFM 35x Power Amps
    Harmon Kardon T45 Turntable w\ Benz MC 20E Phono Cartridge
    Vincent Phono Preamp (not enough gain in the Parasound Phono In)
    Cambridge Audio 640C V2 CD Player
    Nakamichi BX300 Cassette Deck
    Polk RTi 12 Main Speakers
    2 Polk PSW 1000 Subwoofers
Welcome!
Welcome!
