possible cs400i problem
aps1ngh
aps1ngh Posts: 36
edited September 2007 in Troubleshooting
I am wondering what the crossover setup is in the cs400i. I recently purchased this speaker (used) off of a private seller to match my rt800i's and I am concerned about the sound coming from the left 6.5" woofer. The right woofer seems to have richer and deeper sound while the left seems much more distant and recessed for much of the mid and lower frequencies. I can only tell this difference when I am testing them and putting my ear directly up to the speaker. From a distance, everything sounds fine.
By touching both of them simultaneously, I know both drivers are working (from touch, they feel as if they are being driven equally) and sound is being put out out by both, but I would like to know if this is a problem with the left driver possibly being damaged, or if this is how the speakers are intended to sound due to the internal crossover setup. I checked my Yamaha preamp settings and everything checked out so it's either my ears or it's my speaker.
Please let me know. Thank you.
Post edited by aps1ngh on
  • rskarvan
    rskarvan Posts: 2,374
    edited August 2007
    I believe the two CS400i drivers are crossed-over to different frequencies.
    The RT800i drivers both deliver the same frequencies.
    The CS400i drivers overlap... but, are setup to be centered to different frequencies. Nothing is wrong with your center speaker. Thats just how it is designed.
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited August 2007
    rskarvan wrote: »
    Agreed mine is the same :)
    BTW The BEST Center speaker ever IMHO :D
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • aps1ngh
    aps1ngh Posts: 36
    edited August 2007
    Thanks for your input guys. That is exactly what I was hoping. The midrange drivers on the 800i are the same frequency but I was scared about the 400i drivers because they delivered different frequencies (the right one goes lower) so I thought I'd ask. I was considering buying another driver to replace it, but I am very glad I asked here first.
    From a distance the speaker sounds fantastic. So beautiful. The little cs245i I had before simply didn't cut it I'm gonna turn into a rear center channel and I'm going to try to get my hands on some older fx series or possible 600i's to complete an HT setup! :D
    Thanks fellas.
  • ViperZ
    ViperZ Posts: 2,046
    edited August 2007
    I had exactly the same question previously when I switched from CS245 to CS400. LOL.
    Panasonic PT-AE4000U projector for movies
    Denon AVR-X3600H pre/pro
    B&W CDM1-SE fronts
    B&W CDM-CNT center
    B&W CDM1 rears on MoPADs
    DUAL NHT SubTwo subwoofers
    Oppo BDP-93 Blu-Ray player
    Belkin PF60 Power Center
    Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
  • rtart
    rtart Posts: 835
    Well, I'm stupid! I never noticed, even after lots of room EQing. Another reason why this forum rocks!
    My 7.4.4 DIY 4k Home Theater:
    Polk LSiM 707 L-C-R, LSiM702 side surrounds, LSiM 705 rears
    Polk LSiM 702s x 4 on the Ceiling Atmos speakers
    2 x SVS PB12/Plus 2's
    Denon X3700H
    Emotiva XPA11 Gen 3
    XBox One X 4k & BD and streaming
    Panasonic UB-420 4k player
    HD-A35 HD DVD
    Oppo BD-103D for hirez audio
    Technics SL-D2 TT, Grado Gold Cartridge
    JVC DLA-RS2000/NX7 projector
    Silver Ticket 120" acoustically transparent screen
    Berkline 090 electric recliners with Aura Bass Shakers
