Tivo?
ridged84
ridged84 Posts: 6
edited October 2010 in The Clubhouse
anybody use it ? Is it good? Can it be used on a HDTV?
Post edited by ridged84 on
  • mantis
    mantis Posts: 17,563
    edited October 2002
    No it cannot be used on a HDTV DSS or HDTV cable,but it can be used with regualr cable or dss.
    I own it, I love it .....Football never will be the same without it.Or any other tv watching for that matter.
    TiVo is the way to go....no tapes and full control of all your shows.
    Down the road HDTV will be recordable and TiVo will be right there........there can be only one.........for this matter it does have a name..........TiVo he be!!!!!!!!!!
    Dan
  • ridged84
    ridged84 Posts: 6
    edited October 2002
    Im using reg cable through my HDTV .Can i still use it?If so what unit do you think is a good bang for the buck?
  • RuSsMaN
    RuSsMaN Posts: 17,985
    edited October 2002
    I'm curious, why can it not record HDTV? Can it not handle the signal? Just wondering.....
    Cheers,
    Rooster
  • goingganzo
    goingganzo Posts: 2,793
    edited October 2002
    you can also add hard drives to up you recording time
  • mantis
    edited October 2002
    It doesn't have the digital inputs video or audio.Second HDTV is copy write protected right now.
    Dan
  • jrausch
    jrausch Posts: 510
    edited October 2002
    Last Question.
    Hey Mantis,
    Does that protection stop the computer PVR systems from recording?
    "The only way to get rid of a temptation is to yield to it."
  • goingganzo
    edited October 2002
    i am going to wait for the next gen of pvr i want one that can do high qualty and digital audio you just buy the one with the smallest hard drive and then go buy a 200 gig hd and you are set and i cant wait for divx to be suported divx is alot better encodeing than mpeg 2
  • jdavy
    jdavy Posts: 380
    edited October 2002
    Tivo is great! I have two direct-tivo units in my house. If you have kids and need to stop the TV and fix dinner, change a diaper or walk the dog, you can not live without it. Once you have tivo you will never go back to regular TV. I even catch myself in the car wanting to replay the news broadcast to catch what I missed. Too bad thier is no tivo audio. BTW who wants to watch comercials? Only some of the supper bowl ones are really great.
  • mrbigbluelight
    mrbigbluelight Posts: 9,878
    edited October 2010
    So .... is this Tivo thing the real deal or just a fad ?
