PsW505
  • WilliamM2
    WilliamM2 Posts: 4,804
    edited September 2007
    You need to go into the Yamaha's setup menu and turn the subwoofer "on", then set your speakers to small. That will route the bass to the sub.
  • FittyFieFo
    FittyFieFo Posts: 482
    Did, nothing happened
    Samsung LN52A850 (52" 1080P LCD TV) | RTi A9's (Fronts) | Csi A6(Center) | FXi A6 (Rear Surrounds) | SVS PB12-NSD (Sub) | Oppo BDP-103 | Panamax M5300-PM
    Pre-Amp: Marantz AV7005 | Amp: Emotiva XPA-5 | Speaker wires: Signal Cables | Interconnects: Signal Cables
  • 66chevyIISS
    66chevyIISS Posts: 857
    you said the green light is on, but you didn't say if the volume on the actual sub was turned up. Should be about 1/4-1/2 turn.
    My Home Theater (WIP):
    Panasonic AE900 Projector - 126" screen, XBOX 360, Pioneer BDP-320 Bluray
    Receiver: Denon AVR-1905
    Fronts: RTi6's, Center: CSi5, Surrounds: RTi4, Rears: Denon
    Dual Subs: PSW202, and behind the couch Denon 8"
    My showcase link:
    Media Room pics
  • FittyFieFo
    Yep knob was more then 1/2 turned.
    Although, when I do put it on standby, it turns yellow after like 10-15 minutes.
    Also in my manual it says that a LFE IN Light or something like that should be lit up if there is one plugged in..on the receiver display.
    That doesn't show up.
  • 66chevyIISS
    If it goes to standby while you are listening to something then it sounds like your sub is not receiving any signal at all. Does your manual for your reciever have a troubleshoot section for not sub output? or I would call polk customer service and have them walk you through it. Sounds like a setting or your LFE pre out to me.
    My showcase link:
    Media Room pics
  • FittyFieFo
    Number?
  • 66chevyIISS
    Customer Service:
    polkcs@polkaudio.com
    9am - 6pm, M-F, EST (USA)
    800-377-7655 toll free phone
    410-764-5470 fax
    My showcase link:
    Media Room pics
  • FittyFieFo
    thank you!, will give them a call tomorrow
  • askinquestions
    askinquestions Posts: 80
    Try plugging into the the pre-out sub on Yama, then the in or red input on the sub. Make sure your setting in the yama have sub and not none.
  • FittyFieFo
    I put everything for SUB on. Nothing worked when I put the cable in (L or R). But when I did put the cable in the RED OR WHITE input on the sub, the bass went off but then stopped.
  • Lainar
    Lainar Posts: 16
    Have you tried using speaker wire to connect to the high level inputs and then connecting your speakers to the output on the amp?
    HT Rig
    Fronts: RTI12
    Center: CSI5
    Side: RTI10
    Rear: FXI5
    Sub : SVS PC20-39
    HK 645
    Sherbourn 7/2100A Power Amplifier
  • FittyFieFo
    No I have not. Not really sure what to do on that part?
    Plug my RTi10's into the subwoofer?
  • 66chevyIISS
    did you call polk?
    My showcase link:
    Media Room pics
  • FittyFieFo
    I currently can't breathe (I'm sick) I will try tomorrow if I feel better
  • FittyFieFo
    Anyone live close to NIU? Wanna help me :) lol
  • 66chevyIISS
    wild stab in the dark here, but if you go into your test tones setting, what db is your sub set at? see page 56 in your yamaha manual if you don't know how to do it.
    My showcase link:
    Media Room pics
  • FittyFieFo
    FREQ: 80Hz, is that what u were looking for?
  • FittyFieFo
    I've talked to Polk and Yamaha customer service. They said, it could be the receiver...
  • FittyFieFo
    So I played with the receiver some more...
    I got the subwoofer to work, but I need the volume on the SUB to be on MAX to hear it...
    ANy suggestions?
  • askinquestions
    FittyFieFo wrote: »
    I'm sure your door will be banging down after you just said you were sick.:eek:
    As for your last question, I'd just ditch the 505 and look into what you can afford right now. There's a ton of subs out there to p/u that would put a smile on your face.
