LSiFX or LSi7's
I am looking to replace my surrounds with either the FX's or 7's and wanted to know some opinions. I listen mostly to music about 70% and about 30% HT. I would prefer stands instead of mounting to the walls. How are the FX's for music compared to the 7's?
_______________________________
Mains............Polk LSi15 (Ebony)
Center...........Polk LSiC
Surrounds......Polk RM6600
Subwoofer.....Polk PSW450
Pre\Pro..........Denon 3805
DVD........Denon 2910
Theatre System 5.1
Receiver Denon AVR 3805 Pre/Pro
Adcom 5503 amp (front L/R & centre)
polkaudio Lsi15 (Ebony)
polkaudio LsiC Centre
polkaudio RM6600 Surround
polkaudio PSW1000 Sub (Ebony)
Denon 2910 DVD Player
Post edited by fish976 on
i just bought the lsi15's. cant wait til they come in. i also got the lsi-fx. i see u dont have an amp. u must think they sound fine with out one... both of the speakers u are choosing are on sale at the jr retail store. u should call for prices.Home Theater
lsi 15's, lsi c, lsi f/x
onkyo 805
sunfire tga 5200
toshiba - xa2
panasonic bd30
sony kdl40v2500
svs sb12+ -
This really depends on placement. Both speakers are excellent for replaying music. Maybe the Lsifx's could be said to be alittle better. Some may say different.
I have owned both and found they both work well. Placement should determine the right speaker.
DanDan
Yes, I work right across the street from J&R so I am practically in there every day and yes they have the best deals right now on Polk.Theatre System 5.1
Denon 2910 DVD Player -
I am also looking for a deal on a good AMP. I am planning on it soon. I can either get the FX's or 7's first and save for the amp next or get the amp now. I hope the amp will make a difference here when I get one.....Theatre System 5.1
yes, i too am working on getting a decent amp (can be very costly). to make matters worse, i have a depth issue with regards to my entertainment center. only 17" depth. i have been scouring (sp?P) ebay and audiogon. but not sure i can pull the trigger on used equip, although i realize that is probably the better way to go.
how do the speakers sound with out the power amp? it can go either way, holiday season is coming up so should find deals on both items in the next coming months. (at least that is what i am hoping for. I still need a new dvd player and subwoofer as well) this home theater project i embarked on is costing me more than i would have ever thought. all started with, i would like a new lcd tv and snowballed into changing everything i have. of course my sister doesnt mind because she gets all the replaced items. instant home theater set up.:DHome Theater
onkyo 805
sunfire tga 5200
toshiba - xa2
panasonic bd30
sony kdl40v2500
svs sb12+ -
To me the sound from my 3805 isn't that bad. My only comparsion is in J&R they have a adcom GFA 5500 and the LSi15's do sound better than mind. Now that I would be looking for a amp do I get a 2 channel or 5 channel?Theatre System 5.1
I found the LSI-7 to be much better for music than the Fx, afterall, the 7 is made for music and the fx is intended for use as a surround speaker, if you want them for music the 7 would seem to be a no brainer to me.
RT1 -
reeltrouble1 wrote: »I found the LSI-7 to be much better for music than the Fx, afterall, the 7 is made for music and the fx is intended for use as a surround speaker, if you want them for music the 7 would seem to be a no brainer to me.
RT1
+1..or the 9's.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000 A
Parasound HCA 1000
Oppo BDP 95
Von Schweikert LCR 4 Center
Totem Mask Surrounds X4
Sony PS3
Squeezebox Touch
I would def. look into getting an amp first before the surrounds. You said you listen mostly to music so an amp would def. be the better thing to go for right now.58" Samsung Plasma (on wall)(calibrated)
LSi15's front (modded xo's)
LSic center
LSiFX's sides
LSi7's rears
Sunfire Sig. 600 amp for 15's
Sunfire Sig. Cinema for C,S&R
Sony ES 3000 pre/pro
SVS 2039 PC Plus sub 12.3 (16hz tune)
PS3
Wii
Signal and Audioquest ic's
12 awg monster speaker-cable (bi-wired)
Belkin PF60 power conditioner
Monster power conditioner for sub
