Growing grass
Willow
Not that kind, our new place has some dead grass patches.
We bought some seed and some earth. We have had luck in some areas but others look like crap. Just looking for tips on growing/starting grass seed.
Overall our lawns look much better but it could look that much better due to some of those dead patches.
thanks
thanks
To fill in dead spots, rake the dead grass out and plant new seed about 1/4 inch deep in the loose soil. Make sure you keep area moist after
check out this link: http://www.vigoro.com/BrandNav/HelpfulHints/LawnCareBasics.htmReceiver: harmankardon AVR235
Mains: polk R30
Center: polk CSi3
Rear Surrounds: polk R20
Subwoofer: polk PSW404
DVD: Panasonic DVD-S29 -
We have done this and this one spot started to grow and then just died. I'm thinking we may have to go out and buy a piece of sod, cut out the dead spot and insert the new sod.
Try mixing some fresh soil with the seed. If that doesn't work then maybe the sod should take.Receiver: harmankardon AVR235
Mains: polk R30
Center: polk CSi3
It's illegal here stateside.
Are you using starter fertilizer?"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
I will try this, this weekend, I'll put it in a bucket and mix it together. then spread it and water it. -
Scott's bagged top soil – contains starter fertilizer
Scott's Premium Sun\Shade Grass seed
I have to patch at least 3 dog pee spots a week in my back yard and this stuff does the trick. Work the seed into the soil as mentioned above and within 4 days I have new grass coming up and stays healthy until the dog pees on it again. If your grass is dying after it comes up, it sounds as if it's not getting enough water. -
ill tell you but you are gonna have to karma some grass to me...
Grass needs lots of water no matter what. Germinating grass seed and seedlings need to be kept moist. I think the general recommendation is two light waterings per day. An impulse sprinkler with a spike to stick it in the ground is your ally here -- if you don't have an irrigation system.
This is a tough time of year to start grass seed... fall's better.
EDIT: The back yard at Casa Hardy during that two-week period in the spring when it looks good :-)
In the doldrums of August, it looks like bat barf out there.
grub worms maybe?
I had the same problem. I thought I only needed grass seed until I consulted with my lawn freak of a neighbor.
Dropped a bag of Scott's Grubex; and viola, patches and spots of dead grass were gone! Started using Scott's fertilizer afterwards, and now I probably have one of the greenest lawns in my subdivision.:) -
My only recommendation:
Don't use chemicals on your lawn. Only the natural stuff.Trey (5:22:24 AM): my Taylos have copper phase plugs
Trey (5:22:26 AM): they shiney
Destiney (5:22:39 AM): ahaha
Destiney (5:22:57 AM): that gives wrong pictures of you lovingly caressing your taylos copper phase plugs
Trey (5:23:25 AM): >_>
Trey (5:23:27 AM): Mayyybe
Trey (5:23:31 AM): I do dust them, does this count?
Destiney (5:23:22 AM): do you linger?
Trey (5:23:49 AM): not normally
Destiney (5:23:35 AM): then its okaaaaay -
Girl_Addicted wrote: »My only recommendation:
Really??
You in the lawncare business?? -
I failed this recommendation miserably -
We don't cause our little dog is outside all the time eating the stuff and we walk around barefoot in the backyard. -
Dog ****?:D
Dog ****?:D
Or cow and compost. Either way. The chemical stuff is bad for the water system and for the Earth. Plus, if you give it to your lawn, it's going to depend on it and you'll end up wasting a lot of money. It's easier to use the natural stuff once.Trey (5:22:24 AM): my Taylos have copper phase plugs
mhardy6647 wrote: »This is a tough time of year to start grass seed... fall's better.
Maybe I'll wait till then. The previous owners had a dog which is what made all the patches. Our dog has never killed grass before. She doesn't pee often in the yard, usually other people's as we take her for 3 walks a day. -
Milorganite.
Wow, great looking yard MHardy!2007 Club Polk Football Pool Champ
"It's like a koala bear crapped a rainbow in my brain!" -
Really??
Actually, I've had a lot of experience working in the yard. And I've taken Chemistry and Environmental Science, which gave me enough common sense to know that chemicals are bad for a natural setting.
Plus, if he were looking for advice from a person in the lawn care business, he would have went to someone who claimed to be in the lawn care business, not the Club Polk forum.
I have a tree you can hug on.
Thank you.
I know that was meant to be insulting, but it's not really.Trey (5:22:24 AM): my Taylos have copper phase plugs
I think Demiurge has a crush.
Willow, for better info we need to know what kind of grass... temps... symptoms... soil type.. .etc. Pics would help. -
I'm really hoping that tree thing wasn't a reference to something else...
Ewww.Trey (5:22:24 AM): my Taylos have copper phase plugs
How'd you guess? :eek: I prefer the Orange over the Purple, though. -
Umm the green kind in my backyard? I don't know the kind it was put in by the builder late last fall.
I'll take a look tonight. -
Search the internet, it should help you identify the type of grass you have. There are tons of different types of grasses for different regions, so knowing what you have is a start. Then you have to learn it's traits and how to care for it.
Check out this forum:
http://forums.lawncare.com/forum/index.cfm?forumid=1 -
thx Phuz !
