Strange subwoofer noise....
shawn474
shawn474 Posts: 3,052
edited August 2007 in Troubleshooting
I have a quick question that maybe you guys can help me with. I have the euipment listed below in my signature. when I first turn on my receiver and either a cd or DVD first begins playing, I get a strange noise from my sub. The best way that I can explain it is that it sounds like high pitched scratching sound. It lasts for only a second and it nevers happens again until I turn everything off and turn it back on again. It does not happen during movies, cd playback, etc. I have about a 30 foot run and am using a monoprice sub cable that was highly recommended. I have had the same set-up for about a year and I just noticed this maybe a month ago. Any suggestions (besides buying an SVS)?
Thanks in advance,
Shawn
Shawn
AVR: Marantz SR-5011
Center Channel: Polk LsiM706c
Front: Polk LsiM703
Rear: LSI fx
Subwoofer: SVS 20-39pci
DVD Player: Sony PS4
Post edited by shawn474 on
    tonyb Posts: 33,028
    edited August 2007
    Check a few things first.All your connections,includeing the power cord and the pins where it plugs into on the back of the sub.Have you tried useing a different socket to plug it into?Could be picking up something on such a long run.Have you tried a 2.00 cheater plug?The fact that it only happens on powering up or off says it's a ground loop issue or a connection issue.Could also be a loose wire inside by one of the connections.Check it out.
  • Girl_Addicted
    Girl_Addicted Posts: 195
    edited August 2007
    This has happened to me before as well. If it were just during a DVD or a CD, I would say that it's because your system isn't really built for handling music/movies. Like, my system is primarily for music, and it sometimes acts up when I play a movie with a lot of action sequences (and a lot of hard-hitting bass sequences). But, I don't know what to tell you other than that...
    Trey (5:22:24 AM): my Taylos have copper phase plugs
    Trey (5:22:26 AM): they shiney
    Destiney (5:22:39 AM): ahaha
    Destiney (5:22:57 AM): that gives wrong pictures of you lovingly caressing your taylos copper phase plugs
    Trey (5:23:25 AM): >_>
    Trey (5:23:27 AM): Mayyybe
    Trey (5:23:31 AM): I do dust them, does this count?
    Destiney (5:23:22 AM): do you linger?
    Trey (5:23:49 AM): not normally
    Destiney (5:23:35 AM): then its okaaaaay
  • shawn474
    edited August 2007
    I don't think my system is the culprit considering that it worked for over a year with no problems. I have been having some electrical issues in my house and am in the process of replacing the outlets. I will get a cheater plug and see if that works as well. I asked the guy at the hardware store if they carried them and he looked at me like I had three heads. Do they go by another name?
    Thanks for the suggestions.
    Take Care,
    Shawn
    Shawn
    Front: Polk LsiM703
    Rear: LSI fx
    tonyb Posts: 33,028
    edited August 2007
    Lets see,ask for a plug that turns a 3 prong one into a 2 prong one.A ground lifting plug.
