Lsi 9 for sides
askinquestions
If I am going with lsi25,lsic,lsifx, would the lsi9 make sense as surround sides??
*Before you say it, I realize about the 4ohm power.
Post edited by askinquestions on
Overkill.
Go with the LSi7, or another set of FX. -
Why is this over kill???? Are you sayiing it would be kind of like adding another set of 25's for sides as in over kill.... or to put it simply, would be a waste of speaker???
askinquestions wrote: »Are you sayiing it would be kind of like adding another set of 25's for sides as in over kill.... or to put it simply, would be a waste of speaker???
Yes. -
Would it be any better to use the 9 instead of fx for rear???
No.askinquestions wrote: »Would it be any better to use the 9 instead of fx for rear???
The best rears for any Lsi system is the Lsi7's and Lsifx. They work perfectly together. The 9's are better suited for mains or for a 2 channel system.
DanDan
No.
Agreed
DKG999
Music System: Magnepan 1.6QR, SVS SB12+, ARC pre, Parasound HCA1500 vertically bi-amped, Jolida CDP, Pro-Ject RM5.1SE TT, Pro-Ject TubeBox SE phono pre, SBT, PS Audio DLIII DAC -
Thanks for the info
I am thinking of going with LSi7s for my rears as opposed to the FX because I like to play 5-channel stereo music and I am assuming the LSi7 is better suited for music compared to the FX.
The FX can still hold their own with music in the rears. Just have to change the bipole/dipole switch. The LSi9 would be a huge waste of speaker in the rears, FX or 7s all the way as others have suggested also. If youre running subs, you can save some coin and even go 15s instead of the 25s up front.Shoot the jumper.....................BALLIN.............!!!!!
We're among the wasteful, we've got 15's up front, FX's on the Sides and 9's in the back. We purchased the 9's first, and were considering doing 9's front & back and we didn't get the others in time to return the 9's. They are overkill in the rear agreed, but we like the punch they have, certainly more punch than the 7's (most noticeable while listening to SACD's in 5 channel). If we ever put a 2 channel setup together we can steal the 9's from the back of the HT and replace them with 7's or something, but we really like the 9's as well, and with the 15's and the Carver we've got a 2 channel setup which we're quite fond of (we know it's along way from a true 2-channel rig but it's getting it done quite nicely right now for us).Home Theater
Chane A3rx-c's, A2rc-c, A1rx-c's|Miller & Kreisel V-125's|Sony XBR65X810C 65" 4K LED TV|
Earthquake Cinenova Grande-5|Pioneer Elite - VSX-84TXSi-AVR|TRIPPLITE LCR2400|
Ultrasonic Amp Stand|Blue Jeans,Audioquest,Monster Cables|
2 - Channel
Polk RTA 12c's w/RDO194 TWEETS, clarity ESA caps mills resistors (full mod)|Turntable|
Anthem MCA 2|Acurus Act 3 Pre Pro|Parasound P/Ph 100|Pioneer Elite N-30|Adcom GDA600|
Premier Rack|Blue Jeans,Audioquest,Monster Cables| -
If your doing 7.1 ch stereo it is great but for movie watching not much coming out of rear and low music out of sides.engtaz
+1000 - exactly right, for 7.1 or 'All Channels' it's great, overkill for most anything else, not to mention the majority of our music listening is 2 channel anyway...Home Theater
2 - Channel
You've got one kick butt system G2!
As long as you have the space, the power required to run an all LSI system (and you do!!!) to thier full potential, oh yeah & the money for it, GO FOR IT!!!
I really don't understand this concept of overkill. It's somehow wrong or wasteful to get more than you need possibly for the life of your system, but perfectly all right to spend thousands & thousands of dollars building & rebuilding & rebuilding & rebuilding system after system chasing after the ever illusive PERFECT sound.
Asking, Welcome to CP! If you have the means, space, & money for the system you want, GO FOR IT!
Don't forget to post pics when everything is set up!Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
