Common Ground Amp Question
polktiger
Ok, I am going to show to ignorance here...:o
I have a Pamamax 4300 power center, and I plan to run an amp that I understand to have the common ground required for SDA. I assume that it will be ok to plug the amp into the Panamax.
I understand this may be a stupid question, so I will understand any stupid answers. Hopefully other forum members will get a little chuckle at my expense today.;)
Post edited by polktiger on
The "common ground" idea behind SDA's means the two (-) posts of the amplifier which go to the speakers must be tied together internally (as most are). It makes no difference what the amp is plugged into.
Thanks!
It makes no difference what the amp is plugged into.madmax
Unless you are trying to sell some premium power cords or premium power outlets.;)Proud and loyal citizen of the Digital Domain and Solid State Country! -
Do 2 mono amps (1 for each speaker) require strapping the negative speaker terminal together?engtaz
Yes, but some mono amps cannot be connected this way. You should ask the amp manufacturer to be sure.Proud and loyal citizen of the Digital Domain and Solid State Country!
