SDA SRS2's blown drivers
engtaz
engtaz Posts: 7,664
edited July 2007 in Troubleshooting
Ken,
I know 6510's SDA aren't due till Sept. What is the best replacement recommendation? You do have the 6511's stereo drivers I have been told.
???? I noted that the 1.2's use 6511's as SDA and 6503's as stereo drivers.
Would I do the same if 6503 were my closest match????
Last night we had a power surge the blew 3 driver & 3 SDA. Could you PM me some prices. This really hurts. I hope the new RDO tweets did not get hurt.
engtaz
Post edited by engtaz on
  • danger boy
    danger boy Posts: 15,722
    edited July 2007
    wow. you need to move from FL, that sucks!
    we don't get power surges in here in the Northwest.. so that would suck!
    sorry to hear about your situation.. that sucks!!
    PolkFest 2012, who's going>?
    F1nut Posts: 50,841
    edited July 2007
    1-800-377-7655
    You should check the rest of your gear before running your system again.
  • danger boy
    edited July 2007
    ummm. jesse, what's the 800 number for?
    F1nut Posts: 50,841
    edited July 2007
    The number is to Customer Service. I posted it so Mr. Lazy **** can call instead of expecting Ken to PM him.
  • danger boy
    edited July 2007
    ;) gotcha...
  • engtaz
    engtaz Posts: 7,664
    edited July 2007
    I called already. They said that Ken was gone and the driver tech had left for the day. The person told me to contact Ken today and the the drive tech would be in. I am at work in the mourning so the easiest was to get back to me is a PM. As stated, they told me the 6510's were out of stock and won't be available till some time in September. System has already been checked out with other speakers and is still good.
    engtaz
    heiney9 Posts: 25,221
    edited July 2007
    Eng, you and I have been PM'ing about your blown drivers. Now it's my understanding you were running 2 bridged (mono) GFA 555's. One hooked to each SDA, which we discussed is a no no because of the common ground issue. So I'm confused, which is it.........you blew the drivers because of a power surge or because you were running non-common ground amps with the SDA's?
  • Mike Reeter
    Mike Reeter Posts: 4,315
    edited July 2007
    heiney9 wrote: »
    This is a very good question,that there seems to be no answer for.
    "Good" surge protectors are easy to come by,and quite affordable at that.
  • engtaz
    engtaz Posts: 7,664
    edited July 2007
    I believe it was because the common ground Adcom 555II were not common anymore after we bridged each amp and we put 1 555II to left and 1 555II to right. Therefore canceling the common ground amp situation causing a sensation of blownupness. IE we screwed up by not having a common ground amps therefore proving common grounded amp are good not common bad. Boy does it suck to remember rules after the fact. Ouch
    engtaz
  • george daniel
    george daniel Posts: 12,096
    edited July 2007
    I may have 4 very good condition 6510's that I don't need anymore,if anyone is interested
  • engtaz
    engtaz Posts: 7,664
    edited July 2007
    yes yes, all 4 went from my mistake. Just so everyone knows there are no more 6510 at Polk the earliest to get them is September.
    engtaz
  • engtaz
    engtaz Posts: 7,664
    edited July 2007
    Sent: Wednesday, July 25, 2007 4:36 PM
    To: Coulter, Roy
    Subject: RE: 555II ??? Bridged with neg speaker post strapped together for POLK SDA's
    Hello! Roy:
    CAUTION! CAUTION!
    No! You can not tie the amps together in bridge mode for the SDA ‘S. The amps will (blow up). Stereo mode is your only way to Proceed.
    Thx, Eric
    Original Message
    Sent: Wednesday, July 25, 2007 10:31 AM
    To: Eric Walker
    Subject: 555II ??? Bridged with neg speaker post strapped together for POLK SDA's
    Hi,
    We spoke at 1:20 p.m. est. I have 2 555II amps. I want to bridge each amp and feed 1 to the left front speaker and 1 to the right front speaker. I have Polk SDA SRS 2's. They require a common ground amp or they will blow the drivers because the speakers use a SDA wire to share some of the sound from each speaker. I want to know if in the bridged configuration the 2 center speaker post are the one's used in bridged configuration. The left center is negative and the right center is the positive lead. Since the Polk SDA's require common ground I need the jumper the 2 amps together on the left center speaker output post, therefore making the 2 bridge mono amps common ground again. Is this safe? Please get back to me soon.
    Thanks,
    Roy A. Coulter
    FYI email transcript.
    engtaz
  • engtaz
    engtaz Posts: 7,664
    edited July 2007
    That was the earlier version. It only had 2 post and could not bi amped.
    engtaz
  • avguytx
    avguytx Posts: 1,628
    edited July 2007
    Can you do that? I need to look at the crossover layout on both of those in the Compendium and see how they compare.
    Richard? Who's your favorite Little Rascal? Alfalfa? Or is it........................Spanky?.................................Sinner.
  • ben62670
    ben62670 Posts: 15,969
    edited July 2007
    Lasareath wrote: »
    Exactly, It was also 4ohms and really needed a high-powered amp.
    If I had blown drivers in a later version I would most likely install 6511's and 6503's
    6511's for the SDA and 6503's for the stereo drivers. Basically mimicking my 1.2's
    Can do that. The difference in drivers is small.
    Ben
