No sound from main speakers in HT setup
pmckeealaska
pmckeealaska Posts: 808
edited July 2007 in Troubleshooting
I own an LSi HT setup. Yesterday, I moved about 2 hours north of my last residence. I carefully packed up all speakers and other components. When I got to my new house, I set everything up and began testing everything out. The sound from the center and surround speakers was great, but I'm getting no sound from either of my mains. They are LSi25's and when I go through the test mode on my receiver, I get no tones out of the mid and tweeters, but the powered subwoofers of the 25's sound fine. I'm wondering of this is a setup problem in the receiver or if it is a speaker issue. I was listening to movies and music not 48 hours ago at my previous residence and all was fine. I changed nothing in the receiver setup that I'm aware of.
Another problem that I now have is that I my TV will not respond to commands from my remote and I cant get into the proper input select to view the setup menu for the receiver. I suspect the issue lies with the receiver and not the speakers. Does this sound reasonable or do you have any other avenues you suggest I try? Thanks!
Music and Movie Rig
Samsung 40" HDTV 1080p
LSi25 Front Speakers
LSiC Center Channel
LSiFX Surrounds
Rotel RB 1080 2-Channel Amp
NAD T763 Reciever
Denon DVD 2900 Universal Player
Audiosource 10 Band Digital Equalizer
Audioquest CV-8 speaker cables
Audioquest Sub-X subwoofer cables
Audioquest King Cobra Interconnects
Monster AVS 2000 Voltage Stabilizer
Playstation 3 120GB Slim
Post edited by pmckeealaska on
    treitz3 Posts: 19,279
    edited July 2007
    See if the connections to the tweet's and mid's aren't shorted to start. I don't own LSi's, but do they have a fuse for the upper frequencies? Speaker A/B engaged? Volume set to low/mute for mains on receiver?
    Try a hard reset on the receiver if you can't find anything, waiting at least 30 seconds before plugging back in.
