Power for Atrium 45s - Outdoor setup
Ultiman
Ultiman Posts: 26
edited July 2007 in Speakers
I just got my Polk Atrium 45s and will be installing them outside shortly. My question deals with the fact that I need a receiver with a very small footprint to power them because it will be located on top of my kitchen cabinet.
I found a mini system at Best Buy that has an audio in (needed for Apple Airtunes setup) and powers at 120w (assuming I will get 60w/channel).
Will this be sufficient to power the Atriums for minimal outdoor recreational listening? Thanks!
http://www.bestbuy.com/site/olspage.jsp?skuId=8208717&st=insignia+shelf+system&type=product&id=1165610947914
Front: Mirage Omnisats
Center: Mirage Omnisat
Surrounds: Mirage Omnisat
Sub: Mirage Omni S8 (rockin' little 8 incher!)
Outdoor: Polk Atrium 45
Post edited by Ultiman on
  • mantis
    mantis Posts: 17,204
    edited July 2007
    I'm sure it will be fine. You know you should check out Sonos.
    www.sonos.com
    This is where it's at man if you want to send music around your house. Crazy easy to install and setup. I do them all the time and love em.
    Dan
    Dan
  • Ultiman
    Ultiman Posts: 26
    edited July 2007
    mantis wrote: »
    www.sonos.com
    Dan
    Thanks for the suggestion, but I chose a slightly cheaper route opting to use iTunes to control everything and using 2 Airport Express modules routed to my 2 receivers.
    My plan is almost complete...
