Polk SDA SRS
apachef1
Can the Polk SDS SRS speakers be used with mono amplifiers if the amplifiers are common grounded?
Mono amps by nature aren't common ground unless a strap is run between negative posts on the amps. Check with your manufacturer to see if the amps in question can handle this strapping.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
