LSi25 Hookup
fatchowmein
fatchowmein Posts: 2,637
What's the best way to hookup the LSi25's sub section?
1) Polk Way
Sub-out from pre-amp/receiver to subwoofer in on one of the LSi25's then Line Level Out to the Subwoofer In on the other LSi25. This is Figure 7 in the LSi25 manual.
2) Harmon Kardon Way
Y splitter to both LSi25's
Post edited by fatchowmein on
  • mantis
    mantis Posts: 17,629
    edited June 2007
    1) Polk Way
    I perfer from receiver to first speaker then from speaker to speaker. Using a Y splitter will also get it done. As long as you use high quality sub cables and a sub splitter, it will work the same.
    Dan
    Dan
  • fatchowmein
    edited June 2007
    Thanks, Dan. I guess the Polk way would also make it easier to incorporate another sub down the road if needed by adding the y splitter.
