Opinions on RT2000 and CS350
SteveoSupremo
SteveoSupremo Posts: 2
edited July 2007 in Speakers
Hey
Obviously this is my first post here so I got a question.
I'm looking to buy a set of RT2000 ( i don't know if they are i or p) and a CS350 and 4 Bose161's
the RT's are about 10 years old and the CS350 is about 9 years and the Bose are about 2 years old.
what is the life expectancy of these speakers? being that they are 10 years old would they have started to rot or wear out? assuming they sound excellent and they look good what price would you think would make it a good deal?
SteveO
Post edited by SteveoSupremo on
  • mantis
    mantis Posts: 17,422
    edited June 2007
    If they where taken care of, they can last a lifetime.
    The Rt2000p's are nice speakers. they sound pretty damn good when set up properly. I'm not sure what the going rate is for a pair but they did cost like 2 g's back in the day or somewhere close to that. If you can get them under a grand, I think your doing ok. They may go for less then that though. The CS350 is a nice center channel. Big but very nice. I personally really like it alot.
    You should beable to pick that up cheap.
    Good luck man
    Dan
  • SteveoSupremo
    edited June 2007
    Thanks for the reply.
    I bought them yesterday for $525 and they are now sitting in my family room waiting for a receiver.
    I tried them out with an old surround system that I had and they sounded good.
    one question I do have is that when they are in the AUTO mode or OFF mode how do you know if they are off? does the light on the front go out?
    thanks
    Steve
  • del44
    del44 Posts: 686
    edited June 2007
    Congrats Steve. I just now replaced my RT2000's after 6 years of enjoyment. Awesome speakers. BTW, The green light stays lit all the time.:)
  • mantis
    edited June 2007
    Sounds like you got a good deal on them. Cool man. Yes the green lights stay on forever.
    Dan
  • amulford
    amulford Posts: 5,020
    edited June 2007
    Ihad a set for years, with a 350 for a center. They may be 10 years old (I doubt it), but they are still excellent for what you want them to do. I only got rid of them because I got their bigger brother. I still use the CS350LS for a center, and don't really see any need to change it out.
    Excellent price. Just be careful you don't blow the tweeters, they don't make them any more...
  • venomclan
    venomclan Posts: 2,467
    edited June 2007
    amulford wrote: »
    Anthony, is that the CS350LS you got from me?
    If so, I bought it in December/1997. Glad to hear it is still ticking.
    V
  • ViperZ
    ViperZ Posts: 2,046
    edited June 2007
    I was able to score RT1000p tweeter just last year from local Club Polk rep?
    Panasonic PT-AE4000U projector for movies
    Denon AVR-X3600H pre/pro
    B&W CDM1-SE fronts
    B&W CDM-CNT center
    B&W CDM1 rears on MoPADs
    DUAL NHT SubTwo subwoofers
    Oppo BDP-93 Blu-Ray player
    Belkin PF60 Power Center
    Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
  • amulford
    edited June 2007
    venomclan wrote: »
    V
    Yep.
  • venomclan
    edited June 2007
  • frodaddy
    frodaddy Posts: 124
    edited June 2007
    Lights are always on, but after a few minutes of no signal you'll hear them click off. Put a small piece of electrical tape over the power lights if they bug you... they did me
    Fronts: DIY Statements from htguide.com
    Center: DIY custom Statement center from htguide.com
    Surrounds: Four DIY custom Mini Statements
    Wire: HD-14
    Receiver: Denon AVR-4806 + CI upgrade
    Amps: Dual Emotiva LPA-1's
    Sub: Infinite Baffle: 8 fiCarAudio IB315 woofers, Behringer DSP1124P EQ, Elemental Designs eQ.2, Dual EP4000 amps
    Transducers: 2 buttkicker LFE's, BK amp, EQ'd w/DSP1124p
    DVD: Toshiba HD-XA2 / PS3
    TV: Samsung 1080p 61" DLP
  • imike24
    imike24 Posts: 1
    edited June 2007
  • DollarDave
    DollarDave Posts: 2,575
    edited July 2007
  • dpowell
    dpowell Posts: 3,081
    edited July 2007
    I had a pair of the 2000p's for 4 years. Great speakers! I definitely recommend letting your amp drive the mid/tweeter section and connect the L/R line level outputs from your amp to the line level inputs on the 2000's. IMO, it makes for much cleaner sounding bass.
