Grill pegs sheared off--How to get them out?
seeclear
seeclear Posts: 1,244
edited 2007 28 in Troubleshooting
I was thinking I could try drilling a really small hole into each peg fragment and gluing a toothpick into the peg, then pulling them out once the glue hardened. Any other suggestions?:cool:
TIA
"Don't forget to change your politician. They are like diapers they need to be changed regularly, and for the same reason."
Post edited by seeclear on
  • PolkThug
    PolkThug Posts: 7,532
    edited 2007 11
  • dorokusai
    dorokusai Posts: 25,577
    edited 2007 11
    Are you talking about a vintage or current model Polk speaker?
  • seeclear
    edited 2007 11
    dorokusai wrote: »
    CS245i
  • [Deleted User]
    [Deleted User] Posts: 7,658
    edited 2007 11
    Hello,
    The best method is to use a small, thin nail called a "brad". These are used to hold picture frames together and can be found at most hardware stores. Carefully drive a brad in the center of the broken grille post and use pliers to pull it out.
    Regards, Ken
  • seeclear
    edited 2007 11
    Thanks, all.
  • TurboJim
    TurboJim Posts: 8
    edited 2007 24
    If you havent gotten it yet (its been a month) next time a piece of plastic is broken, heat up a small screw to the point it will melt the piece of plastic. Once hot, press it into the plastic you want to extract. Let it cool a a min and then it will have "glued" itself and you can pull it out
    __________________
    Jim Testa
    jtesta1966@aol.com
    Maint HT:
    Mitsu 55511 HDTV, SDA-SRS 2.3, CS350, RT2000, Denon AVR3806, DBX 3bx/120x, Denon DVD-2900, Sony SA222ES, Carver M1.5t, Monster 3600, SA8300 Cable box/DVR
    Bedroom system
    Sharp AQUOS 32" LCD, Onkyo TSXR800, Bost Acoustimass 15, Pioneer DVD, Pioneer DVD-R
  • seeclear
    edited 2007 28
    OK, so now I got them out. I used a combination of my idea and PolkThug's "tweezer". When I was using a really small drill bit, I found out the piece was actually two pieces, and as I drew out the bit one half pulled out with it, then I just could grab it with tweezers. Voila.
    Now, how do I get/order a replacement for the grill? Do CP members get some kind of discount (I thought I saw that mentioned on here before?)?
    Thanks a lot.
