new speakers- overload/Receiver shutting down?
edited June 2007 in Troubleshooting
I have the following plugged into my system Pioneer VSX D511 receiver with 100 watts per channel.
CS1
PSW 10
R-20
If i try to turn the volume up beyond 45 on the numeric rating; then the receiver shuts down....why?
I had r 20's hooked up with NO problem; then added the sub and center channel. Now I can barely hear the system in the other room. I had the system set for 3.1 config.
I need some advice.
Post edited by Arkansas on
Welcome!
    edited June 2007
    Look into the the speakers you added first since you had the 20's hooked up with no problems
    Have you checked both speaker wire connections to the center channel? Make sure they are both hooked up correctly, positive to positive, negative to negative on both sides (receiver and speaker)
    Receiver: harmankardon AVR235
    Mains: polk R30
    Center: polk CSi3
    Rear Surrounds: polk R20
    Subwoofer: polk PSW404
    DVD: Panasonic DVD-S29
    edited June 2007
    Make sure there are no strands of the speaker wire that are touching each other, or any metal objects. Even touching the receiver's chassis is enough to cause a short (since the receiver is grounded to the chassis ground).
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
    edited June 2007
    appadv wrote: »
    Exactly what I was thinking as well. Good call.
Welcome!
Welcome!
