Help - FX 500 Left Channel Speaker Broken
realjoeyd
Hi,
My wife managed to bump the speaker stand with the vacuum cleaner hard enough to cause my FX/500 left channel surround speaker to come crashing to the floor. :eek:
It is totally dead - no sound at all. The drivers themselves look OK, and I didn't see any obvious signs of damage when I removed the rear plate (where the speaker wires connect).
Any ideas about how I might be able to troubleshoot/fix this? Or, failing that, referral to a good repair facility?
I want to get back to 5.1 ASAP
Thanks!
Joe
Thanks!
Joe
Post edited by realjoeyd on
I'd suggest removing the drivers and checking the solder connections. You might need to resolder any loose connections.polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
Probably the crossover. Unscrew the plate where the binding post are and check for cracks or loose wires. You can pull the drivers and tweeters and touch the speaker wires to the connecting pins and see if you get sound. Make sure you turn the power way down on the receiver. Also, be sure the speaker wires don't touch each other.
Call Polk customer service on Tuesday. They can send any replacement paerts you will need.
Good luck -
If you don't find anything obvious, my first step would be to start troubleshooting with the other surround speaker. Swap drivers, one at a time and see if they work in the "good" speaker. The problem should be pretty easy to figure out.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
Thanks guys... I will try all of these methods to track down the issue.
Oh yeah BTW, I doubt anything is really "broken." Most likely it is an easy fix!polkaudio RT35 Bookshelves
