Are there any current speakers made that use SDA (or sim.) technology?
Yashu
Yashu Posts: 772
edited May 2007 in Speakers
I am curious if there are any speakers being made now that use the type of tech used in the polk SDA.
So many people like SDA, the sound is something that audiophiles and non-audiophiles both seem to love.
If they are so good, why are there not any SDA type speakers currently being made? or if there are, what are the names? Why did Polk abandon this technology, and for that matter, why does Polk's modern lineup seem to have completely abandoned their former style and philosophy?
I would love to own a pair of SDAs but my system's needs can't support a set, and having to restore a vintage pair might be more trouble than it is worth for me... but if there were current speakers that use the technology, speakers made for a modern setup, with shielded drivers (this is a must), that are out there, I would sure love to know about them.
Post edited by Yashu on
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    edited May 2007
  • bbeacham
    bbeacham Posts: 141
    edited May 2007
    Polkmaniac wrote: »
    You mean, like, the SurroundBar
    He probably means standalone speakers like the original SDAs. I have a pair, bought in 1989, in my living room amd they still work great. I bet that technology would make great HT speakers by being able to project a wider sound stage than the LSi series.
  • jakelm
    jakelm Posts: 4,081
    edited May 2007
    I think BOSE has that technology now or some sort of it. And they are making a killing off of it.
    Monitor 7b's front
    Monitor 4's surround
    M10's back surround
    Harman/Kardon AVR-635
    Oppo 981hd
    Denon upconvert DVD player
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
    Dont BAN me Bro!!!!:eek:
  • Systems
    Systems Posts: 14,873
    edited May 2007
    back in the 80's Carver made a component called the Sonic Holography generator that electronically did a similar thing that the SDA's do acoustically.It could be used with any speaker but required precise positioning of the speakers and listener.
    Testing
    Testing
    Testing
  • NeilGabriel
    NeilGabriel Posts: 1,487
    edited May 2007
    GV#27 wrote: »
    I have a Carver CM 1099 with sonic holography. The explanation on why it is needed and how it works is identical to the SDA explanation (well mostly), but they did it with internal electronics and a traditional speaker. No interconnect cable. I had it hooked to my CRS+ and tried with and without the SH.
    My burning question is this. Seriously. The SDA technology is based on the fact that sound from traditional speaker drivers reaches the right and left ears and thus the stereo separation is minimized. Right? But SDA and SH send a cancellation signal to direct the right speaker to the right ear and left to left. Right? But this is not how we hear live music, is it? Doesn't it reach both sides of our head? So, is SDA and SH an effort to achieve true stereo or a sound effect? I honestly don't know, but I have puzzled over this and imagine it has been the subject of raging debates. As usual, I have probably made very faulty assumptions.
  • Systems
    edited May 2007
    It is purely an effect to widen the stereo image which it certainly did if set up correctly.
    Testing
    Testing
    Testing
  • jakelm
    jakelm Posts: 4,081
    edited May 2007
    Speakers in phase, speakers out of phase. Like simulated surround.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
    heiney9 Posts: 25,440
    edited May 2007
    Go to POLKSDA.com and read the 2 Stereo Review articles, especially the one for the SRS's they explain how it works. It's a rather complicated and technical subject abd you have simplified it too much.
  • NeilGabriel
    edited May 2007
    For those where SDAs are your speaker of choice, I am sure this is not an issue, but when I had the CRS+ hooked up, I posted before how they continued to play (sda drivers) even when the speaker button was punched out--ok, easy, turn off the source. Also, they continue to play if you want to switch to B speakers which I wanted to do. Mine also continued to play when I used headphones. And of course, they even play with one speaker wire connected! None of this happens when the IC is disIC...but then why have them? I assume this is true for all SDA speakers. None of this is a big deal unless you want the option of switching to a set of B speakers.
  • NeilGabriel
    edited May 2007
    heiney9 wrote: »
    H9. I absolutely agree and no one should even think I understand the technology. I don't. I also am not at all critical of it...more curious than anything and anything too technical is beyond my ADHD afflicted brain.
    I'm still trying to figure out how a stylus dragged over a groove in vinyl creates an electronic signal that can be played back as music!
  • MillerLiteScott
    MillerLiteScott Posts: 2,564
    edited May 2007
    A question for the SDA Guru's.
    Does or will a D'Appolito array work on the stereo side of an SDA speaker with the SDA speakers in their normal configuration? Or does this create some time alignment issues and that is why the tweeters are in the center of the stereo and SDA mid woofers?
    And while I am at it. When utilizing PR's, do they cancel out some sound when the PR moves in when the mid woofer is moving out and vice versa?
    Also how does the fluid coupling not get all muffed up when the stereo mid woofer is moving significantly different than the SDA mid woofer?
    Scott
    I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
    F1nut Posts: 51,786
    edited May 2007
    That is not normal. I'd have to say something was wrong with your speakers or your gear.
    F1nut Posts: 51,786
    edited May 2007
    I'd suggest you read the SDA white papers as they explain it much better than I can, but let's say you've made faulty assumptions.
  • dudeinaroom
    dudeinaroom Posts: 3,609
    edited May 2007
    Yeah, mine don't do that either(once the adcom drains the caps anyways.)
    F1nut Posts: 51,786
    edited May 2007
    Scott,
    I can't answer your first question and no to the second one, which answers your third one.
  • Systems
    edited May 2007
    Scott
    Im not an SDA Guru, but the PR' s purpose is to extend the bass response of the mid bass drivers exactly like a port would on a bass reflex speaker.My guess is that it is probably?only used to augment the bass of the stereo mid bass drivers and not the SDA drivers.
    not sure what you mean by fluid coupling.?
    Testing
    Testing
    Testing
  • Yashu
    Yashu Posts: 772
    edited May 2007
    Yes, the SDA drivers aren't in the same chamber as the others and the PR. I don't think. At least that is what I have seen from the various SDA cross sections.
    The SDA drivers only use a narrow band, with the later SDA revisions having an even more narrow band for the SDA drivers. Polk found out that using a narrow band for the SDA drivers even can increase the effect, probably because of how the higher frequencies are way more directional, and of course the low frequencies are way more non-directional, so they don't really need the effect, leaving a more narrow midrange band for the effect to work it's "magic". (the compact SDA was possible only after Polk made these updates to the technology, I am pretty sure)
    And no I wasn't talking about the sound bar, that is similar maybe, but I was hoping for something to use with 2 channel, and with the improvements in bookshelf speakers over the recent years, it would be awsome to have a modern compact SDA-type monitor, especially to use with nearfield, since that is eactly where wide soundstage becomes a problem. The vintage compact SDA is still too large, not meant for nearfield, and not shielded, so it wouldn't work well in nearfield situations anyhow.
    Too bad speaker design is so complicated... hehe... these days it is so easy to order quality components and drivers online, and there is enough documented on polk's designs that I am sure a competant engineer could one-off build a set, bu thent I am a CAD/designer, so I only have to deal with engineers, not actually be one ;)
    I just never understood why the technology was abandoned in the first place, SDA was obviously a good product. Probably some marketroid decision.
    F1nut Posts: 51,786
    edited May 2007
    Ok guys, get your read on here as there's plenty of SDA info to be found.
    The SDA drivers are not in a separate chamber and the compact SDA CRS was around long before the updates. As for sheilding, adding bucking magnets is easy and effective, so that's a none issue.
  • Bill Ayotte
    Bill Ayotte Posts: 1,860
    edited May 2007
    The Carver piece you are talking about is the C-9....ALMOST all Carver Pre-amps and receivers have it, minus the C-19......The C-9 is a stand alone hologram generator.
  • NeilGabriel
    edited May 2007
    A fairly confident forum member, Hoosier I think, claimed that the speaker on/off button just closed the positive line and that the speakers could run on the negative alone--which they also do if I disconnect only one speaker cable. I don't know, maybe if someone modded the mids, they wired some offball way. All I know is that when I removed the IC, they stopped. Engtaz will now get to figure this out. The speaker off button works just fine with my other speakers, so I doubt it is the equipment. Eng, if you read this, see what you find out.
  • Systems
    edited May 2007
    Thanks Bill thats the one.The only time I have ever heard SH was with one these simple black boxes hooked up in a system.
    Testing
    Testing
    Testing
  • Yashu
    Yashu Posts: 772
    edited May 2007
    It's your amp I think?
    Don't some amps run with a DC offset? Could that be the problem if everything wasn't sharing a common ground?
    I did get my read on. But I have seen the compact SDA, and it has only one tweeter per speaker, and that would mean that the tweeter was not being used as part of the SDA effect... but I thought that on the larger SDAs with several tweeters per speaker, one or more were being used for the SDA effect along with the mid-driver(s), and that polk changed things around so that this was not the case later on, and it made the crossover much simpler and so on.
    Also, if the SDA drivers were not isolated from the passive radiator, then how did polk keep... wait... I just answered my own question in my head, the SDA drivers were not exactly out of phase at the same TIME, as they were adjusted for time as well as phase... nevermind on that one :)
    F1nut Posts: 51,786
    edited May 2007
    The original CRS uses two tweeters.
  • hoosier21
    hoosier21 Posts: 4,418
    edited May 2007
    early SDA models used a tweeter (in addition to the midwoofer(s)) on the SDA portion, later models removed the tweeter and only used the midrange driver(s), even the later model big boys with several tweeters.
    As said before, the internal of the cabinets do NOT have separate chambers for the SDA drivers.
    Yashum the only "delay" is the from the SDA drivers physically being 7.5" +/- to the outside of the cabinets
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
  • NeilGabriel
    edited May 2007
    Yashu wrote: »
    I'm running a Carver CM 1099 int amp (without sonic holography on). I have no idea what a DC offset is..sorry. I wish I had checked this with another amp/receiver....I hate riddles.
  • Yashu
    Yashu Posts: 772
    edited May 2007
    Then how come the SDA drivers being out of phase with the mains, do not adversely affect the passive radiator performance?
    Is it because the PR's resonance freq. is such that the narrow band the SDA drivers use doesn't have an effect?
    I guess, all this thinking about the SDA system makes me realize that it is certainly not without it's little flaws, and that many purists probably would shun them. I like the updated approach that did not involve a tweeter in the SDA set, it seems like they would be more forgiving.
  • hoosier21
    edited May 2007
  • hoosier21
    edited May 2007
    Yashu wrote: »
    that is the answer
    BTW windows Media Player's SRS WOW is VERY similar to the CARVER system
  • Systems
    edited May 2007
    Yashu wrote: »
    If the SDA drivers are hi pass filtered(bass removed) then the PR would only be augmenting the bass output of the main mid bass drivers.
    Sorry I know I should be researching this but what is the stated bandwith of the SDA drivers?
    Testing
    Testing
    Testing
  • MillerLiteScott
    edited May 2007
    I have seen my SDA driver moving out when the stereo driver was moving in or vise versa. I believe it was drums in Steely Dans Aja specifically. Yashu you may right that the SDA driver(s) only? operates above the PR's tuned frequency response.
