looking for a sub to go with lsi9s
kolyan2k
kolyan2k Posts: 259
edited May 2007 in 2 Channel Audio
60% music, 40% movies. 15x20 (maybe more) room, and its an apartment building, so i don't really want neighbors complaining. my fronts are LSI9s powered by Outlaw monoblocks.
i was thinking Outlaw LFM-2 or maybe HSU STF-2....what do you guys think ?
http://www.hsuresearch.com/products/stf-2.html
http://www.outlawaudio.com/products/lfm2.html
Post edited by kolyan2k on
    VR3 Posts: 28,774
    edited May 2007
    Check out VMPS
  • Early B.
    Early B. Posts: 7,900
    edited May 2007
    Either the Outlaw or the Hsu would be great choices. Go for it.
    "God grooves with tubes."
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited May 2007
    Is the budget $350 or so?
    You need something pretty fast to keep pace with the 9's. Polk has a SLEW of new subs coming out, you might want to wait a bit.
    If you need to do something now, look at a used Vandersteen or JM Lab.
    Cheers,
    Russ
  • engtaz
    engtaz Posts: 7,664
    edited May 2007
    I like the HSU but also look a Velodyne and SVS. I am not sure about the Outlaw subs.
    engtaz
  • kolyan2k
    kolyan2k Posts: 259
    edited May 2007
    engtaz wrote: »
    HSU STF-2 is somewhere between LFM-1 and LFM-2. STF-1 is the same thing as LFM-2. i read alot of good reviews on these two
  • janmike
    janmike Posts: 6,146
    edited May 2007
    My room is about the same size as yours. (18.5 X 16)
    I have a SVS PB12-PLUS with LSi9's and it works great for both music and HT.
    As for the neighbors, you live in an apartment so the control is the volume and you. I would think that any sub would alert close neighbors if turned up. Good Luck.
    Michael ;)
    NORTH of 60°
  • kolyan2k
    kolyan2k Posts: 259
    edited May 2007
    thanks guys. i will look up recommended subs. i want to spend about $500 or less
  • mantis
    mantis Posts: 17,201
    edited May 2007
    Save as few more bucks or get one used but this will be all you need for a sub under a grand. It's fast, very responsive and not overly agressive.
    You look is over.
    http://www.us.martinlogan.com/speaker_intro/dynamo.html
    Dan
  • kolyan2k
    kolyan2k Posts: 259
    edited May 2007
    mantis wrote: »
    You look is over.
    thanks. i am reading some good reviews....that its good with music etc.
    i'll think about it
  • kolyan2k
    kolyan2k Posts: 259
    edited May 2007
    mantis wrote: »
    You look is over.
    picked up new Dynamo black for $360 at local store (was the last one for this price, so i didn't even think about it)
  • engtaz
    engtaz Posts: 7,664
    edited May 2007
    Congrats. How does it sound.
    engtaz
  • mantis
    edited May 2007
    engtaz wrote: »
    The sub is quick and responsive. It's as musical as any su you ever heard under a grand. It's ability to blend in with a pair of speakers is uncanny. It's an amazing little woofer.
    Built quality is top notch. Much better then most subs on the market at and below it's price range.
    I Install this sub all the time and it makes me smile every single time. I'm very cridical on subs. I think most of them suck. This little guy is awesome.
    Dan
  • janmike
    edited May 2007
    Congrats. Glad you found something that fits the bill.
    Michael ;)
    NORTH of 60°
  • kolyan2k
    kolyan2k Posts: 259
    edited May 2007
    engtaz wrote: »
    well.....i am not an expert, and i have not listened to any other subs...: ) i trust forums almost 100%.....that said, i like how Dynamo blends in with LSi 9s while listening to music. and the other best thing is i paid $360 for it.
    ps. I have LSi 9s with Outlaw monoblocks connected to Rotel RC-1070 and i use Oppo DV-970HD for playing. sub is connected to 2nd output on Rotel w/ RCAs.
    LSis, Outlaws, and Oppo were all recommended here !
  • engtaz
    engtaz Posts: 7,664
    edited May 2007
    Trusting us, your scaring us. LOL
    I like your choices
    engtaz
  • Polk65
    Polk65 Posts: 1,405
    edited May 2007
    Something that may help keep the peace with your neighbors is putting a slab underneath your sub. This helps decouple it from your floor and reduce some of the bass sent to the next apartment. Granite, marble, and sink cutouts from kitchen counter tops (fake marble) are all good.
