jolida tube amps and lsi's
JimBRICK
JimBRICK Posts: 1,543
edited May 2007 in 2 Channel Audio
I want to put together a value 2 chan set up.
do the jolida products mesh well with the LSI7's?
2 CHANNEL
Speaker - Klipsch Heresy II
Under construction
Post edited by JimBRICK on
  • Yashu
    Yashu Posts: 772
    edited May 2007
    Are you thinking of their all tube amps or their hybrid amps.
    I would say that you would need one of their hybrid amps to get the power you need for the LSi.
  • madmax
    madmax Posts: 12,434
    edited May 2007
    You can use very high powered amps with the LSi7's. Tube power really doesn't cut it with them unless you listen fairly softly.
    madmax
    Vinyl, the final frontier...
  • pearsall001
    pearsall001 Posts: 5,092
    edited May 2007
    That's a tough one to call. You'd really have to give one a listen paired up with your 7's to see well how it performs. For what it's worth, I had a 502B running my AAD 2001 monitors, which are very power hungry (86db/8ohm). They sounded wonderful but the 502B didn't have enough "umph" for my liking. I've since moved on to my AVA ss amp & it is a perfect match.
  • JimBRICK
    edited May 2007
    so let me ask this then, for a 2 channel setup what would you pair with the lsi7's?
    I was looking at some integrated amps but I thought tubes were the way to go with a 2 channel setup
    btw the jolida I was looking at was
    JD 1501A
    http://www.jolida.com/catalogue/models/jd1501.shtml
    2 CHANNEL
    Under construction
  • JimBRICK
    edited May 2007
    oh well I think I found what I'm looking for
    http://www.outlawaudio.com/products/rr2150.html
    and look at that price
    2 CHANNEL
    Under construction
    F1nut Posts: 50,731
    edited May 2007
    You're looking at two completely different animals. The 1501 is a hybrid integrated with SS power and a tube pre amp section, which should drive the LSi 7's without issue. The Outlaw is a SS receiver complete with tone controls....UGH!
  • engtaz
    engtaz Posts: 7,664
    edited May 2007
    I an lost on this thread.
    engtaz
  • Yashu
    Yashu Posts: 772
    edited May 2007
    Don't knock tone controls. As long as it has a defeat they can be mildly useful. I crank them up when I break in a set of speakers, makes break in go a lot faster, but that is about all they are useful for.
    Like I said earlier about the hybrid amps, I think they would work, just not the all tube amps. I almost bought one of the hybrids. They are a damn good deal.
  • madmax
    edited May 2007
    I would look towards a higher power seperate amp and preamp to get the best in 2 channel. For about the same price as the outlaw you can find a good used 2 channel 200 to 400 watt amp which would really do a nice job with the 7's. Something of the sunfire/carver nature or other decent class amps. It all depends on where you want to go more than anything else.
    madmax
  • JimBRICK
    edited May 2007
    I want to keep this easy to use (wife) and relatively cheap. The outlaw has tons of power and with an all in one usit the wifey can use it too :) Seeing that the 7's are actually 6 ohm they should be easy to power with this integrated. I find theres too much trouble for tubes for me. I want to be able to flink on a switch and away I go.
    2 CHANNEL
    Under construction
  • madmax
    edited May 2007
    The Jolida should sound much better if I had my guess. Not sure of the price difference.
    madmax
  • JimBRICK
    edited May 2007
    actually the prices were bang on. but with little knowledge of tubes and no one around that I can get to come help hands on, I'm a little gun shy of buying one.
    2 CHANNEL
    Under construction
    F1nut Posts: 50,731
    edited May 2007
    1. The Outlaw is NOT an integrated amp, it's a receiver. The Jolida is an integrated amp.
    2. They are both SS power and both rated at 100wpc @ 8 ohms. The only tubes in the Jolida are in the pre amp section and should easily last 10,000 hours or more. You don't even have to bias them, so what trouble, you've never owned tube gear?
    3. Either one one is power up and play, so your wife will be happy.
    4. All the help you'll need is right here at Club Polk.
    5. The Jolida will sound better.
  • JimBRICK
    edited May 2007
    ok ok f1 lol.
    yes I've never had anything tube before but have heard them and think they are more alive
    You've sold me on the Jolida which is what I wanted anyways. I was just a little apprehensive because of what I've read here.
    I figured the 100w of tube power would be plenty for these speakers
    settled done and done. I am ordering that jolida in a few weeks when my speakers are closer to arriving
    2 CHANNEL
    Under construction
  • Midnite Mick
    Midnite Mick Posts: 1,591
    edited May 2007
    There you go.
    Having a tube preamp and having tube amps are totally different. A simple tube preamp is hardly no maintenance at all. Just keep a single set of replacements for when needed. It is also fun to do a little research and try other ones if you get bored.
    Mike
    edit: Jim just beat my post.
    Modwright SWL 9.0 SE (6Sons Audio Thunderbird PC with Oyaide 004 terminations)
    Consonance cd120T
    Consonance Cyber 800 tube monoblocks (6Sons Audio Thunderbird PC's with Oyaide 004 terminations)
    Usher CP 6311
    Phillips Pronto TS1000 Universal Remote
  • JimBRICK
    edited May 2007
    so how do different tubes do different things? a tube is a tube isnt it?
    2 CHANNEL
    Under construction
  • madmax
    edited May 2007
    http://store.tivocommunity.com/merchant.mvc?Screen=PROD&Store_Code=EA&Product_Code=1303&Category_Code=
    Is this the same one? I've heard of others buying from this site.
    madmax
  • engtaz
    engtaz Posts: 7,664
    edited May 2007
    wooooo wrong thing to say (tube is a tube is that like saying a speaker is speaker or a sub is a sub) LOL
    engtaz
  • madmax
    edited May 2007
    Different tubes have a slight variation in tonal output. Some are better, worse or different from each other. No biggie but a good way to upgrade some day when you decide you want it to sound a little different.
    madmax
  • JimBRICK
    edited May 2007
    AHHHH I get you. Like spark plugs in a car you get different reactions from the way their built
    2 CHANNEL
    Under construction
  • cfrizz
    cfrizz Posts: 13,415
    edited May 2007
    You all obviously didn't bother reading the specs of the LSI's 7's
    Electrical
    Overall Frequency Response 45Hz - 27kHz
    Lower -3dB Limit 53Hz
    Upper -3dB Limit 26kHz
    Nominal Impedance 4 ohms
    Recommended Amplifier Power 20 -150 w/channel
    Efficiency 88 dB
    Crossover 2.4kHz; HPF 18dB/oct, LPF 12dB/oct.
    Inputs Dual 5-way binding posts for bi-amp/bi-wire
    These are NOT 6ohm speakers, nor does Polk describe them that way.
    Running these speakers on a 50wpc Rotel amp had it frying an egg at the end of the listening session.
    Power them properly for best results.
  • JimBRICK
    edited May 2007
    cfrizz wrote: »
    Electrical
    Efficiency 88 dB
    Actually if you've read on the net the people who have actually sat down and rated these after testing them they found they were running at 6 ohms. Check out the november 2006 issue of affordable audio test on them
    2 CHANNEL
    Under construction
  • cfrizz
    edited May 2007
    Sorry Jim, but I would think Polk would know why they rated them at 4ohms regardless of what other people tested them at.
    Ken I see you on here. Why were they rated at 4ohm?
  • JimBRICK
    edited May 2007
    Joey_V wrote: »
    if it makes you feel you somewhat better... the lsi7 is closer to being rated a 6ohm speaker according to measurements done by stereophile and a fellow forum member.
    :p
    check out the rating they gave
    2 CHANNEL
    Under construction
  • madmax
    edited May 2007
    JimBRICK wrote: »
    Absolutely correct. I could not have come up with a better analogy.
    madmax
    F1nut Posts: 50,731
    edited May 2007
    It would be worth inquiring at Jolida if the 1501 is rated to drive less than an 8 ohm load. Their site doesn't say.
  • jrlouie
    jrlouie Posts: 462
    edited May 2007
    JimBRICK wrote: »
    Just for clarity, this is not 100w of tube power. It is a hybrid (i.e. - 100 watts of solid state power with an internal tube pre-amp to give it that lovely tube sound which can be a very nice combination).
  • markmarc
    markmarc Posts: 2,309
    edited May 2007
    The JoLida 1501 will have no problem with the Lsi7's. Unfortunately, when I had the 7's in for review they were sent back just a day or so before the 1501A I'm reviewing showed up.
    My Onix SP3 Integrated tube at 38wpc a side made the 7's sing. You won't have a problem. Remember, quality power is far more important then quantity power with the LSi's.
    Former Staff Member TONEAudio
    2 Ch. System
  • Midnite Mick
    edited May 2007
    Where is the sentiment that tubes do not work well with the Lsi's coming from. My tubes drove the 15's with no problem at all. They could drive them at db's far greater than most of us could tolerate (room is only 10 x 17 however) and still keep the bass under control.
    Thanks,
    Mike
    Consonance cd120T
    Usher CP 6311
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited May 2007
    I have no idea Mick. The 9's were demoed at the Lone Star Audio Fest on a Dodd 50w/ch EL34 amp and they sounded great, and played plenty loud too.
