New theatre system question about DVD Audio...
Naeeldar
Naeeldar Posts: 10
edited May 2007 in Electronics
Today I just picked up the following HT setup:
RTI8 Front
FXI3 Rears
CSI3 Center
PSW10 - Not a hard hitter I know but it's a condo
Yamaha RX-V661 reciever
Anyway one ofthe thing impressed me was the surround sound audio cds. Now I'm planning on connecting a panasonic up-converting DVD player to the home theatre system to play DVD Music discs can I use this or basically what arep eople using these days to play cds? I have the ipod connected to the yamaha so I saw no reason to get a regular cd player. Anyway want to pick up a few of these dvds to show off the new system and because they sound spectacular.
Post edited by Naeeldar on
  • ViperZ
    ViperZ Posts: 2,046
    edited May 2007
    Don't forget to pick up 6 analog interconnects to hook up your DVD-A player to the receiver :).
    Panasonic PT-AE4000U projector for movies
    Denon AVR-X3600H pre/pro
    B&W CDM1-SE fronts
    B&W CDM-CNT center
    B&W CDM1 rears on MoPADs
    DUAL NHT SubTwo subwoofers
    Oppo BDP-93 Blu-Ray player
    Belkin PF60 Power Center
    Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
  • cfrizz
    cfrizz Posts: 13,415
    edited May 2007
    Welcome!
    Lots of people use their dvd players to play their cd's So it will be fine.
    And do be sure to get all the IC's you need to play DVD-A's & SACD's.
    Here is a good option that won't cost you an are and a leg.
    www.bluejeanscable.com
  • engtaz
    engtaz Posts: 7,669
    edited May 2007
    Naeeldar wrote: »
    RTI8 Front
    FXI3 Rears
    CSI3 Center
    I used to blame my keyboard for mispelling but then I found out I can't spell and type well. :D
    engtaz
  • Naeeldar
    Naeeldar Posts: 10
    edited May 2007
    ViperZ wrote: »
    Analog over HDMI? Any reason why?
  • NeilGabriel
    NeilGabriel Posts: 1,487
    edited May 2007
    I imagine that like optical audio, HDMI is a digital signal which is not used for those formats. But someone will quickly correct me if I am wrong.
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited May 2007
    Ok, well maybe I am just old and feeble here folks, where does he get the DVD-A from, not a standard DVD player, you cannot get DVD-A over a digital line to a receiver. Well, you can use an I-link but that is it.
    Naeeldar,
    Welcome to Club Polk, the DVD-Audio disc is a high-resolution disc that uses a form of pulse code modualtion, the best are the MLP process which was invented by Bob Thomas at the Meridan Audio Company--MLP=Meridian Lossless Process, Mr. Thomas' company makes several outstanding players for DVD-A that are also very pricey.
    I would recommend a universal player for your needs, it will play either DVD-A or the other high rez disc called a SACD, these also play all the formats, so they are called universal players, there are many companies that make these, a couple of favorites used by members here are Denon and Pioneer.
    I hope that helps. I definetely recommend you explore high resolution audio, its great. Get the best player you can, you will be glad in the end.
    RT1
  • NeilGabriel
    edited May 2007
    I believe he said he has a panasonic upconverting dvd player (with HDMI). I have two models of these with the S77 being the better. It at least plays DVD-Audio and HDCD. The only thing it does not play as I recall is SACD. The point I was making is that he cannot play DVD-Audio through the HDMI cable (at least that was my thinking). He needed analog cables to that. (ain't it great to have people talk about you like you're not even in the room?)
  • wingnut4772
    wingnut4772 Posts: 7,519
    edited May 2007
    You can play DVD Audio via HDMI as long as you have a receiver that will pass the audio through HDMI.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000 A
    Parasound HCA 1000
    Oppo BDP 95
    Von Schweikert LCR 4 Center
    Totem Mask Surrounds X4
    Sony PS3
    Squeezebox Touch
  • Bill Ayotte
    Bill Ayotte Posts: 1,860
    edited May 2007
    Don't forget Marantz Universals! They play some good noise man...I love the DV-8300....The DV-7001 is right up that alley......
    http://us.marantz.com/Products/2109.asp
    F1nut Posts: 51,778
    edited May 2007
    I'm 99% sure he's talking about DVD video discs of music venues , not DVD-A. The DVD-V discs are not hi-rez, he's just woed by the surround sound feature, which for the most part sounds un-natural to the serious listener.
    HDMI does not pass DVD-A, to the best of my knowledge, but will pass the audio from a DVD-V disc.
    You have much to learn, so stick around and we'll get you on the right path.
  • VXR8
    VXR8 Posts: 291
    edited May 2007
    HDMI will pass DVD-A (version 1.1 or higher), but will not pass SACD unless the version is 1.2 or higher. The Marantz model mentioned above has HDMI 1.1 (as does the DV9600), whereas most AVRs are running at least 1.2a, if not 1.3 these days. Shame that the player specs aren't keeping up with the AVR specs!
    Regards - Gaz from the land of Oz
    Main System
    Denon - AVC-4700H
    Emotiva - XPA-9
    Cambridge Audio - Azur 851C - CXUHD
    Polk Audio - Legend L800 - Legend L400 - Legend L900 - LSiM fx - OWM3
    SVS - PB1000 x 2
    Foxtel - iQ4
    Belkin - Pure AV PF40
    Sony K77A9G
    Front Room System
    PS Audio - Sprout 100
    Cambridge Audio - CXC S2 - CA752BD
    Sony - UBX800 4K BluRay
    Polk Audio - Legend L200
  • reeltrouble1
    edited May 2007
    I really doubt it and I am for sure not going to take some internet guy's advice.............................err....................I guess that would be me.......
    RT1
    Well, IF HDMI version whatever can pass DVD-A and IF HDMI version of another can pass SACD we are all just as screwed as when we started, I will just use analog connects which actually works until I feel like using some HDMI version xxxxxxxxxxxxxxxxxx. However, I believe he was talking about DVD-V. Things do change and did. Somtimes HDMI can pass a high rez signal if the gear supports it, its not about versions per say but what manufacture's choose to have their components support, seems confusing, so just because one version xxxxx of HDMI can pass one signal it does not mean it actually will. Like I said, I will just use analog which actually works.
    RT1
  • cfrizz
    edited May 2007
    RT1Well, IF HDMI version whatever can pass DVD-A and IF HDMI version of another can pass SACD we are all just as screwed as when we started, I will just use analog connects which actually works until I feel like using some HDMI version xxxxxxxxxxxxxxxxxx.
    Amen to this Ted!!!
    However, I believe he was talking about DVD-V. Things do change and did. Somtimes HDMI can pass a high rez signal if the gear supports it, its not about versions per say but what manufacture's choose to have their components support, seems confusing, so just because one version xxxxx of HDMI can pass one signal it does not mean it actually will. Like I said, I will just use analog which actually works.RT1
    The rest of this just gave me a headache! Not something I need on a Monday morning.:eek: :p:D
  • reeltrouble1
    edited May 2007
    sorry cat, this HDMI stuff is for the younger ones, ole RT1 has a tough time with it, in the end it will probably be better, someone mentioned the manufacture's not being able to keep up and just picking certain "options" of HDMI to work on there machines.
    Maybe one day it will get worked out but who knows.
    RT1
  • cfrizz
    edited May 2007
    You're not the only one having a hard time with it Ted! It's precisely the reason I have basically ignored all of it. Some people have obviously forgotten the old saying..."KEEP IT SIMPLE STUPID!!!"
  • VXR8
    VXR8 Posts: 291
    edited May 2007
    Just for the record guys, I too use analogue cables as IMO they still sound as good, if not better than HDMI.
    I actually did a comparison yesterday watching a normal 5.1 DVD - flicking between inputs of "Multi Channel In" (MCI) (Tara Labs ICs) and "DVD" (HDMI) on the same player (Yammie DVD-S2500). To me, it sounded "richer" with a deeper bass via the MCI, which left HDMI to handle video only.
    I think there is a misconception out there that because the DVD is in "Dolby Digital", it's delivery needs to be the same via optical, HDMI etc., whereas analogue MCI is delivering the same effects.
    My AVR has HDMI version 1.2a and my DVD player has version 1.1. I too earlier on in the piece "believed" that HDMI / iLink was better, but saw the light when comparing Multi channel SACD (DSOTM). When it comes down to it, cfrizz has it right with the KISS principle.
    Ciao for now.
    Main System
    Denon - AVC-4700H
    Emotiva - XPA-9
    SVS - PB1000 x 2
    Foxtel - iQ4
    Sony K77A9G
    Front Room System
