Jolida 801a
marvda1
marvda1 Posts: 4,963
edited May 2007 in Electronics
anyone know anything about the jolida 801a tube integraded amp?
http://www.jolida.com/catalogue/models/jd801a.shtml
i can get a new one with remote for $1280 free shipping and 2 year warranty.
anyone compared the jolida to the tad-60 at $1344 shipped with 3 year warranty?
Puritan PSM156
Post edited by marvda1 on
  • dane_peterson
    dane_peterson Posts: 1,903
    edited May 2007
    Jolida makes a lot of great integrated tubies. Check out Audiogon, there's several 302s, 502s, etc. As far as I know, most of them are very well respected.
  • Early B.
    Early B. Posts: 7,900
    edited May 2007
    For half of that price, you can get a used 502. Spend the extra $600 on tubes, power cord, interconnects, and possibly some mods.
    "God grooves with tubes."
  • madmax
    madmax Posts: 12,434
    edited May 2007
    For $1280 I would either:
    A: Jump on it and don't look back
    OR
    B: Double that amount and look for something much better used.
    madmax
    Vinyl, the final frontier...
  • marvda1
    edited May 2007
    it;s my understanding that the 801a uses jolida's best power supplies thus making it much stronger and better sounding than the 502.
    Puritan PSM156
  • marvda1
    edited May 2007
    bump, i need to make a decision soon.
    Puritan PSM156
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited May 2007
    if you gotta have new, go for it, heck, its your dough, but I will spend for you in a heartbeat.
    RT1
  • Early B.
    edited May 2007
    For $1,280, buy a used SS amp for $750 - $800 and use the remaining funds for a tube pre-amp. That combo may serve you better than the Jolida alone.
    If I had to choose between the Jolida and the TAD, I'd go TAD without hesitation.
