Inside look at the Candela...
VR3
So I popped the hood on the Candela to change the tubes out.
Was pretty impressed with the components used.
Post edited by VR3 on
Lots of unused space. Pretty.engtaz
I think the empty space has to do more with interference and so say the remote senor, pot etc dosnt add noise - could be wrong.
Thanks- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Looks nice Trey.polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
very niceAudio: Polk S15 * Polk S35 * Polk S10 * SVS SB-1000 Pro
HT: Samsung QN90B * Marantz NR1510 * Panasonic DMP-BDT220 * Roku Ultra LT * APC H10 -
Thanks for the pics.
No problem.
Thanks for the comments.
I was impressed with the use of Solen caps in certain places. Pretty impressive I thought.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
The white Caps on the board behind the tubes are Sonicaps. notice the Vishay/Dale resistors on the same boardVr3MxStyler2k3 wrote: »No problem.
Rogue Audio stereo 100 tube amplifier - Lector Zoe preamplifier with 6H30 pi's
.Audience AU24SE speaker and ic cables- Chord Qutest DAC - Black Cat Silverstar II 75ohm digital cable-Tyler Acoustics Linbrook Signature system with large bass cabinets to accommodate 10" Seas magnesium woofers.
The ideal preamplifier would be a straight wire with Gain,but it does not exist in the real world. sometimes less is moreLots of unused space. Pretty.
