DVR box cuts out while turning DLP on
Face
I have a Scientific Atlanta Explorer 8300HD DVR box and a Samsung 56" DLP. When turning the DLP on, the audio will sometimes cut out.
I'm using a HDMI cable and optical out from the DVR to my Onkyo, then HDMI to my DLP.
Is this normal for a HDMI connection?
TIA!
TIA!
Post edited by Face on
It's normal because of the HDCP handshake that goes on when you connect an HDMI+HDCP device to another device equipped with HDCP.polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
Thank you."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
No problem. Mine does this also.polkaudio RT35 Bookshelves
