no color
jd61
Just hooked up my new Yamaha RX-V659 A/V receiver and for some reason i have no color when using DVD player or Gamecube. TV is fine. I doubt it is the receiver . Did i not wire something properly. Any help would be greatly appreciated.
Post edited by jd61 on
I would guess loose cable, or wrong setting within the receiver's setup.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
what are you using composite,s-video,component or hdmi?
Usually the component cables colors are mixed up or you need to set the DVD up for component out.engtaz
I had this problem until about a month ago. I finally decided to make a switch to a color TV, and man what a difference!
LOL too funnyengtaz
wwwwwwwwaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
I have component hookups i believe. R,W and Y. Real electronic wiz aren"t I.:o
component is RGB
Red, Green, Blue some people mix the Green and Blue sometimes.engtaz
