Buzzing or Humming Speakers Help!
lschweigman
lschweigman Posts: 1
edited May 2007 in Troubleshooting
We have just spent a few thousand dollars on a new TV and audio system. We have a Denon receiver, Polk in wall/ceiling speakers and used monster cable for all of our cables. We ran the speaker wire when we were re-doing the drywall in our house a few months ago and was sure that the electrical wires and speaker wire didn't touch.
Problem. We have just hooked everything up and when the lights are on there is a loud buzzing/humming sound coming out of the speakers. When the lights are off it sounds great. What can we do to fix this problem?
The lights are on a different circuit than the tv/audio setup and the speakers are about 2-3 feet from the lights.
Thanks!:confused: :mad: :confused:
Post edited by lschweigman on
    F1nut Posts: 52,234
    edited April 2007
    Is the speaker cable shielded?
  • Neskahi
    Neskahi Posts: 297
    edited April 2007
    For the record, what type of lights are they?
    SDA 2.3/RDO's... xovers by Ben
    SDA 2.3TL/Stock..
    SDA 1C/Solens/RDO's [gave to my Uncle]
    SDA 2B RDO's
    Snell Type CV
    SDA 1.2TL's
    GFA7700 Adcom
    GFP750 Adcom
    TFM55X Carver
    M90 Pioneer/C90 Pre
    M91 x 2 Pioneers/C91 Pre
    Yaqin MC10l
    DCD-1520/1560/2560 Denon
    Marantz DVD-8400
    Carver m1.5T
    DV-79avi Pioneer
    TFM35X x 2
  • adam2434
    adam2434 Posts: 995
    edited April 2007
    Are the lights on a dimmer?
    5.1 and 2.0 ch Basement Media Room: Outlaw 975/Emotiva DC-1/Rotel RB-1582 MKII/Rotel RB-1552/Audiosource Amp 3/Polk LS90, CS400i, FX500i/Outlaw X-12, LFM-1/JVD DLA-HD250/Da-Lite 100" HCCV/Sony ES BDP/Sonos Connect. DC-1/RB-1582 MKII/Sonos Connect also feed Polk 7C in garage or Dayton IO655 on patio.
    2.1 ch Basement Gym: Denon AVR-2807/Klipsch Forte I or NHT SB2/JBL SUB 550P x 2/Chromecast Audio.
    2.0 ch Living Room: Rotel RX-1052/Emotiva DC-1/Klipsch RF-7 III/Sony ES BDP/LG 65" LED.
    2.0 ch Semi-portable: Klipsch Powergate/NHT SB3/Chromecast Audio.
    Kitchen: Sonos Play5.
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited April 2007
    Did you install the in-wall speaker wire next to any AC power cables?
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • danger boy
    danger boy Posts: 15,722
    edited April 2007
    dimmer would be my first guess also..
    any florescent (sp) lights in the room?
    and like F1Nut said.. is the speaker wire sheilded?
    is the buzz/hum on all speakers or just some of them?
    PolkFest 2012, who's going>?
    treitz3 Posts: 20,236
    edited April 2007
    Are the electrical wires running parallel to the speaker wires? Within say, 6 inches [or closer] or so over a long run?
    Could you clarify as to whether it is a buzz [high frequency] or a hum [low frequency]? Or both?
  • Serendipity
    Serendipity Posts: 6,975
    edited April 2007
    I use an APC power conditioner and this has eliminated all of my humming problems.
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • scottdwagner
    scottdwagner Posts: 106
    edited May 2007
    Also check for ground loops. Unplug each piece of equipment and see if it goes away. I agree that this is probably the dimmer.
    Monitor Audio GR 60, GR10, GRLCR
    Velodyne HGS18
    Emotiva MMC-1
    Parasound Model 5250
    Denon DVD-3800
    Pioneer pdp-5070
    Secondary HT with B&W CDM-NTs all around and Rotel Separates (thanks Venom!)
