The Odyssey Audio Candela
VR3
VR3 Posts: 28,774
edited April 2007 in 2 Channel Audio
Is bigger than my amp...
Im just sayin...
Post edited by VR3 on
    VR3 Posts: 28,774
    edited April 2007
    I guess yall need pics...
    I know I know - the Shanling deserves a lil better view and space! I AGREE!
    However, the Candela is 1" - yes, 1" wider than my amp and it looks really funky on top of my amp. I can't put the amp on top of it for obvious reasons.
    The remote is really dinky - no big deal, however the unit itself has an anodized silver aluminum finish all over the entire unit... WBT output jacks
    A stout preamp, through and through and sounds amazing - even out of the box...
    Once I get the Stratos, Candela will most likely go down in the rack on top of the Stratos...
  • Serendipity
    Serendipity Posts: 6,975
    edited April 2007
    Nice! Did you get my email?
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • Serendipity
    edited April 2007
    I wouldn't recommend that, as the amp will get hot.
    VR3 Posts: 28,774
    edited April 2007
    Not the Stratos...
    Stratos has an enclosed top and massive heat sinks on the exterior of the amp (sides)
    And No, I did not.
  • Serendipity
    edited April 2007
    Okay, I understand. Since the Stratos dissipates heat from the sides you should be okay.
    Weird - I don't know if it's my firewall or something else. I'll try again.
  • dbnh
    dbnh Posts: 194
    edited April 2007
    I used to have a Stratos with cap upgrade, and it never even ran warm. I now own Odyssey Extreme Monos, and they have a slight warmth to them all the time, doesn't seem to get any warmer even with heavy use. YMMV.
  • Ricardo
    Ricardo Posts: 10,636
    edited April 2007
    Eveything is coming slowly together for a great rig. Congrats.
    SOPA
    VR3 Posts: 28,774
    edited April 2007
    Thanks everyone. Appreciate the comments.
    Everything is coming together a lil faster than planned - kind of. Klaus has been a huge help and very trusting. Great guy through and through and cant recomend his products enough.
    Cant wait to get the Stratos.
  • halo
    halo Posts: 5,616
    edited April 2007
    Stunning man. Simply stunning. You done real good bro.
  • engtaz
    engtaz Posts: 7,664
    edited April 2007
    It's pretty and matches your other equipment LOL Congrats
    engtaz
    VR3 Posts: 28,774
    edited April 2007
    Thanks guys
  • fatchowmein
    fatchowmein Posts: 2,637
    edited April 2007
    Sid,
    If you get a chance, would you give us a review? Why did you go with Odyssey Audio? What were you using before? Likes? Dislikes?
    Thx
    VR3 Posts: 28,774
    edited April 2007
    Its kind of hard to decide what made what difference in my latest upgrade.
    Reason is - this upgrade I did the following...
    1) Added acoustic panels...
    2) changed the tubes on my CDp
    3) Received the Candela
    With this in mind, I can comment on what did change however. With the idea that acoustic panels can only alter the sound so much.
    Right off the bat, no warm up and no burn in. the Candela is far more refined and seperated than my previous rpeamp (B&K PT5) - instruments have a "body" and depth. Everytime is extremely distinguishable.
    And like every upgrade Ive done in audio - drums sound better and better. They have alot of depth and resonance and sound authorative and large. Something always lacking.
    I dunno man - I dont know what to tell ya. The B&K PT5 was no slouch, but the Odyssey is a good 2 or 3 steps ahead of it.
    Why did I go with Odyssey? Well Sean (Zero) recomended them to me. I always had thought they were out of my price range...but I checked them out and found it possible (since alot of their products are not listed on their site).
    All of their units are top notch stuff, extremely overbuilt and robust. the Candela is a beast, anodized finish all over - extremely thick case. Aluminum knobs, whole nine yards. Just extremely impressive build. All the units are built as you order them. Fresh off the lot is an understatement...
    With a 20 year warranty and top notch customer service - cant go wrong.
  • fatchowmein
    edited April 2007
    Sweet. Thx for the quick reply.
    VR3 Posts: 28,774
    edited April 2007
    No problem...
    If I had any complaints about this unit...
    1) They have not developed a manual for this unit yet
    2) Its wider than the Khartago
    3) Its remote is very DINKY
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited April 2007
    A. Turn it on, start twisting knobs - you don't need a manual.
    2. And? What's a Khartago, a breed of Rhino in Africa?
    D. Does it function, and do what it is supposed to do? Maybe you would have preferred to pay $300 more for something milled or billet?
    Now, do you want some tubes for it or not?
    Cheers,
    Russ
    VR3 Posts: 28,774
    edited April 2007
    The Khartago is my amp by Odyssey - and the Candela is wider than it, makes no sense...
    I like to have manuals - just for resale purposes.
    There wasnt an option for a better remote, but I will most likely get a universal remote before long - so all is well....
    And yes, I still want tubes for it. You are the best Russ, thanks.
  • W WALDECKER
    W WALDECKER Posts: 900
    edited April 2007
    No problem...
    Hey Vr3,if you Ask Klaus nicely he may swap Your little black plastic remote control for a Silver Aluminum Symphonic Line remote. the Candela case is the same width as the Stratos case. i really like the Solid Aluminum remote for my BAT VK 3i but the only problem is that the Candela easily outperforms the VK 3i. the lettering on the front and back of the Candela is pretty self explanatory as far as controls and functions. all that he sent to me with mine was a remote control and a spec sheet.my favorite tubes to run in the Candela are the Amperex Holland ECC186/7316 " D" getter White logo PQ's. Enjoy ;) ....WCW III
    Rogue Audio stereo 100 tube amplifier - Lector Zoe preamplifier with 6H30 pi's
    .Audience AU24SE speaker and ic cables- Chord Qutest DAC - Black Cat Silverstar II 75ohm digital cable-Tyler Acoustics Linbrook Signature system with large bass cabinets to accommodate 10" Seas magnesium woofers.2xhmpsuownoj.jpg
    VR3 Posts: 28,774
    edited April 2007
    A spec sheet would of been better than -nothing- ;) (You get my point?)
    Thats cool, as long as the stratos is the same width...
    The preamp though is amazing...
  • Serendipity
    edited April 2007
    So what exactly is on the "dinky" remote control? I would imagine source, volume, and tone controls (I would set them flat) but other than that why so bad?
    I would recommend a universal, programmable (macro enabled) remote. Makes life a lot easier.
    VR3 Posts: 28,774
    edited April 2007
    What are tone controls? LOL
    This unit has no tone controls...
    Source control is "Get-Off-Your-Rear Beta 1.01"
    Only thing on the remote is volume. Thats it.
    The remote itself is black plastic - has enough holes for 20 or so odd buttons, only two buttons filled with grey rubber buttons. The 18 or so odd empty holes have black "foam" filling their voids.
    Its very dinky and unimpressive for such a component.
    However, as mentioned - a Uni remote is in my future... lol
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    edited April 2007
    Looks great, Trey!!
    You may want to wipe those silver brushed units down before your prints sink into the finish. Somethin' in your skin-oils will definately do damage before you know it.
  • george daniel
    george daniel Posts: 12,096
    edited April 2007
    Trey,, pm your addy, I've got a little something for that Candela :)
  • Serendipity
    edited April 2007
    They are those little knobs that allow you to adjust treble and bass. haha
    Since you don't have them, I guess they are already "flat."
    VR3 Posts: 28,774
    edited April 2007
    Thanks for the comments guys.
    I wiped the units down after I took the pictures and saw the prints...
    PM will be headed your way shortly George.
  • steveinaz
    steveinaz Posts: 19,538
    edited April 2007
    Very nice setup Sid.
  • W WALDECKER
    edited April 2007
    The 12AU7 Valves are the Tone Controls :) ....WCW III
  • Shizelbs
    Shizelbs Posts: 7,433
    edited April 2007
    Very impressive.
    Do you even try to show off your system to your peers? I would imagine its all beyond them and over their heads.
  • AndyGwis
    AndyGwis Posts: 3,655
    edited April 2007
    Shizelbs wrote: »
    Agreed. I'm 26 and my friends all think I'm nuts. My friend asked me to help him put together a system for $600 - $700. I told him that would be a good amount for the receiver, and he freaked out.
    Great system, though, despite what the masses might say about your (and our collective) sanity.
    Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
    Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850
  • dbnh
    dbnh Posts: 194
    edited April 2007
    Da Rig -
    Mains - Tyler Acoustics Taylo 7u
    Amplifier - Odyssey Audio Khartago (Soon to be Odyssey Audio Stratos Extreme)
    Preamp - Odyssey Audio Candela
    CD Player - Shanling CDT100A
    You might want to call Klaus, cancel the Stratos Extreme, and instead just go for the Extreme Monos. Admit it, you're going that route anyway...:D
    On a milder note, I used to own a cap-upgrade Statos. When I changed over to the Extreme Monos, I was blown away at the effortlessness of the monos; my SDA 1Cs never sounded so good. When I subsequently moved to dedicated 20A lines, the Extremes could strut their stuff even more (as could the rest of the system); again, the SDA 1Cs never sounded so good. I feel Klaus' gear (as I imagine most gear), improves as the power to it improves.
    YMMV. FYI - wouldn't mind hearing a Candela, but wish Klaus would make the Candela preamp with a phono section (like the Tempest).
