RTi4 speakers: horizontal or vertical placement?
randy wicker
randy wicker Posts: 3
edited April 2007 in Troubleshooting
i just purchased a pair of RTi4 speakers. the size and shape of the shelf i put them on has made me lay them on their sides, horizontally. will i get as good a sound guality as placing the vertically, with the tweeter above the woofer, rather then side by side"?
Post edited by randy wicker on
  • randy wicker
    edited April 2007
    i just purchased a pair of RTi4 speakers. the size and shape of the shelf i put them on has made me lay them on their sides, horizontally. will i get as good a sound guality as placing them vertically, with the tweeter above the woofer, rather then side by side"?
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited April 2007
    Either way is fine, especially with a small bookshelf speaker like the 4.
    Welcome to the boards, and thanks for choosing Polk Audio.
    Cheers,
    Russs
  • Eric W
    Eric W Posts: 556
    edited April 2007
    One thing I'll add is if placing the speakers horizontally- which you may do, be sure that they are a mirror image- meaning both the tweeters are on outside or the inside.
    -Eric
    -Polk Audio
