Panamax 5500 - not enough high current outlets
cnjvh
So I picked up a 5500 EX and found that it only has 2 high current outlets. I have what I would consider to be 4 high current devices - 2 SVS PB10's, a Denon 3805, and a Hitachi CRT RP HDTV.
What's the right way to do this? I could connect the 2 subs into 1 power strip and the TV and receiver into another power strip and connect the power strips into the high current outlets. I know this would void the Panamax equipment warranty but I'm more concerned about the effect this would have on the conditioning benefits?
Anyone else faced a similar issue with this unit?
Thanks!
Thanks!
No earth robot is going to tell ME which button to press!!
--Stuff--
Front: Polk Audio RTi12
Center: Polk Audio CSi5
Surrounds: Polk Audio RTi8 (x4)
Sub: SVS PB10-ISD (Dual)
AVR: Denon AVR-3805
Blu-Ray: Panasonic BD30
Display: Sony KDL-55NX720B
STB: Xfinity X1DVR
--Stuff--
AVR: Denon AVR-3805
STB: Xfinity X1DVR
Post edited by cnjvh on
The TV will benefit the most from the PC IMO. Just protect the SVS's from surge & EMI/RFI. Using a PC can limit the amount of current they recieve / need.Audio: Polk S15 * Polk S35 * Polk S10 * SVS SB-1000 Pro
HT: Samsung QN90B * Marantz NR1510 * Panasonic DMP-BDT220 * Roku Ultra LT * APC H10 -
My Panamax says NOT to plug surge protectors or power strips into it, so I would skip that idea. The Panamax is also rated 15amps max, and if you plug both subs, TV, and your reciever into it, it may overload it.
TV's, even large ones, are not high current devices, so plug that into one of the other outlets, plug the reciever into a high current outlet, and plug the subs dirctly nto the wall. -
i don't connect my subwoofer to a power strip. i plug it directly into the wall outlet. bypass the power strip for your subs, they may draw to much power and make the other components connected to the strip.. blink of flash or something bad.PolkFest 2012, who's going>?
Go subs straight into the wall.Terps Swimming!
HT Setup
TV: Vizio VX32L
Reciever: Pioneer VSX-D914
HD-DVD Player: Toshiba HD-A2
Fronts: Polk R50s
Surounds: Polk R30s
Center: Polk R20's
Subwoofer: SVS 20-39PCi
2CH Setup
Integrated: Onix SP3 Tube
CD Player: Sony CDP-CX355
Speakers: Onix Strata Mini in PR Finish
Signal Cable: Classic Speaker, Analog 1 IC
Headphones
Grado SR 60, Bang & Olufsen A8, Shure e3
Other Stuff in Use
Onix xls, Dual Onix x-subs, Onix Ref .5, Dahlquist M903, Teac A-1D, Marantz 1060 -
OK, thanks for the input everyone. Sounds like the subs are going back to the wall outlets.No earth robot is going to tell ME which button to press!!
--Stuff--
AVR: Denon AVR-3805
STB: Xfinity X1DVR
