SDA 2A cross-over part failure?
deflorio
deflorio Posts: 1
edited April 2007 in Troubleshooting
Have a pair of SDA 2As the mid-range and tweeter appear to be dead in the left speaker. Swapped tweeters. The right speaker tweeter goes silent when placed in the left speaker. Didn't try the mid-range cause I trust whats left of my hearing...
I am guessing this is a component failure in the cross-over. How do diagnose this or better yet get it fixed? It there a common failure mode?
Un solder the cross over and send it to San Diego?
needing help daily..
PdF
Post edited by deflorio on
  • ben62670
    ben62670 Posts: 15,969
    edited April 2007
    Welcome to Club Polk. Did you check the fuse on the back? If there is no fuse the poly switch may have gone bad.
    Ben
