My DVD player is sick!
daboyz
daboyz Posts: 5,207
edited March 2007 in Troubleshooting
I was putting in a CD and the player accepted it and read it. I hit play and it sounded garbled and the player shut down. I unplugged and left overnight. This morning I plugged it in and it powers up and starts to read the disc and shuts back down(can't turn it back on). :( I unplug again and wait and the same scenario happens. My player is a Panasonic RP-91.
Any thoughts or help would be appreciated. Oh, CD is still in there, Zep 4.
Thanks, Dave
Post edited by daboyz on
    edited March 2007
    Open a window,chuck it as far as you can.....hopefully hitting the
    inside of the dumpster.;)
  • daboyz
    daboyz Posts: 5,207
    edited March 2007
    I've only had it a couple of months, please tell me it's not toast.
  • louthewiz
    louthewiz Posts: 581
    edited March 2007
    What brand of dvd player is it?
    is the cd original or a copy,
    we need to know if you want help...
    My gear,
    Acer PH530 720P PJ
    100 inch Da-Lite Video Spectra screen
    Yamaha HTR 5790
    Toshiba HD-A3
    Denon 1600 dvd player with sdi out,
    DVDO iSCAN HD+
    Panasonic Dmr E-80H
    Dishnetwork HD pvr
    1 Audiosource amp300 150 wpc Fronts
    1 Audiosource ampone bridged 200 watts powering center
    1 Onkyo M-282 105 wpc amplifier sides
    polk cs400 center
    polk RT400 mains
    Polk mkII back surrounds,
    Polk FX300fxi dipole surrounds
    Velodyne DPS-10 sub
    Klipsch KSW-10 sub.:cool:
  • daboyz
    daboyz Posts: 5,207
    edited March 2007
    Panasonic DVD-RP91 - original CD
  • danger boy
    danger boy Posts: 15,722
    edited March 2007
    Thanks, Dave
    yeah. get a laser lens cleaner.. that thing is filty dirty... ;) when you rent DVD's from the video store. they are in horrible condition... scratches, dust, fingerprints.. etc.. you need to get a laser lens cleaner.. it will usually solve most problems with players not reading discs. have fun. :)
    PolkFest 2012, who's going>?
  • daboyz
    daboyz Posts: 5,207
    edited March 2007
    But will that cause the player to shut off and not come back on? I have to unplug to get it to come back on, have not been able to retrieve disc out.
    heiney9 Posts: 25,513
    edited March 2007
    Maybe try and google your particular model to find if it's a common problem. I have a Pioneer (2 of them) and I found out *after* it failed that my particular model had a very high failure rate. Atleast I got about 2 years worth of use out of the unit not a couple months like you.
  • daboyz
    daboyz Posts: 5,207
    edited March 2007
    I did a google search and really found nothing. I just did another and changed the wording and found one hit and it sounds like it is the spindle motor. $36 dollar part but I don't have the expertise to do it myself.
  • WilliamM2
    WilliamM2 Posts: 4,808
    edited March 2007
    If it's only a couple of months old, why not have it fixed under warranty?
  • Deadof_knight
    Deadof_knight Posts: 980
    edited March 2007
    should be at least a year warranty
    :cool: " He who dies with the most equipment wins Right ? "
    Denon 3300 Adcom 535 BBe w/sub out 1 pr 4.6s 2 pr of 4 jrs Recent additions Samsung Lns-4095D LCD, Samsung hd-960 DVD, Monster HT-5000 Power center
    ,HPSA-1000 18" sealed DiY home sub.:D
    Black Laquer 1.2tl's w/ upgraded x-overs and Tweets BI-Amped with 2 Carver tfm-35's Knukonceptz 10ga cables
  • Sansui
    Sansui Posts: 372
    edited March 2007
    Is it possible that when the tray closed that the CD wasn't seated properly and now the CD has jammed the tray in the closed position?
    Be gentle, I'm new to all this...
    The mind blowing speed of the BRAIN TRAIN...
  • daboyz
    daboyz Posts: 5,207
    edited March 2007
    Not under warranty,bought used. It could be jammed but I don't think so. If I were to take the top off, would the disc be right there? The hit I found on the web sounds exactly like my problem.
  • Sansui
    Sansui Posts: 372
    edited March 2007
    I don't know about taking the top off and seeing the disc. I've got a Panasonic VCR/DVD player and I've never any problems with it. Why not take the top off and see what the disc is or isn't doing?
    edited March 2007
    No warranty....like I said...chuck it.For what it cost to fix,get another one.
  • BaggedLancer
    BaggedLancer Posts: 6,371
    edited March 2007
    Before you throw it out, take it apart or do anything of that nature...try a cleaning disc.......if not....take it apart or throw it out.
  • daboyz
    daboyz Posts: 5,207
    edited March 2007
    Hindsight is 20/20. Should've just bought the Oppo. But, does anybody know what is reasonable to pay to replace the spindle motor? It was a top of the line player. What does anyone think is worth paying? Please don't say what it is worth to you. Honest opinions please.
    Thanks, Dave
    edited March 2007
    With the part and an hour worth of labor charges,your at 100 bucks,and no
    way of knowing if that will fix all it's problems.You can easily buy a new player for that kind of money.Or a better used one.Anyway,up to you on how to spend a c-note.
  • shawn474
    shawn474 Posts: 3,052
    edited March 2007
    I had a panasonic (though I can't recall the model number now) for about four years and had the exact same problem. Is there an error messgae on the display right before it shuts down? Mine said "H2O". I called customer service and they diagnosed it as a spindle motor drive or some such. I asked the guy if it would be worth it to fix it and he basically laughed at me. Ordered the Oppo that night!
    Shawn
    Shawn
    AVR: Marantz SR-5011
    Center Channel: Polk LsiM706c
    Front: Polk LsiM703
    Rear: LSI fx
    Subwoofer: SVS 20-39pci
    DVD Player: Sony PS4
  • daboyz
    daboyz Posts: 5,207
    edited March 2007
    It seems the spindle motor was more of an issue than I thought. I researched b-4 buying and didn't see anything on it. now it's popping up for a few folks. Bummed.
