Sunfire SDS SRS hum
mangata572
mangata572 Posts: 52
edited March 2007 in Troubleshooting
Just got my SDA SRSs home last night and bi-amped them with my Sunfire 5X400. I am getting a very noticeable hum from the speakers! Before, with the same amp I sometimes would hear a slight (intermittent) hum with my RTi 150s. Now the hum is much louder. What could be the cause? Is the hum just louder from bi-amping?
Post edited by mangata572 on
  • RuSsMaN
    RuSsMaN Posts: 17,985
    edited March 2007
    Ground loop?
  • ben62670
    ben62670 Posts: 15,969
    edited March 2007
    try unplugging your cable TV wire. SDA's allow a lot of currant to run trough them so they pick up noise fairly easily. If that doesn't work try a cheater plug on the power cord as to bypass the ground. Try those 2 easy steps first. If problem persist let us know
    Ben
    Ben
